Thread: Duet Controller or ebay spesh???
02-09-2021 #1
Hello everyone, glad to see the forum is still vibrant with lots of help and interesting builds, not been on here for a while and I have still yet to switch the big ooznest workbee up.
2 items which are really playing on my mind are spindle choice and the controller. I have built the kit from scratch and installed the duet but not even switched it on. After watching various youtube tutorials it just doesnt seem like a decent controller to me, my other machine uses a planet cnc controller which works great. No silly macro's ect.
I am just wondering if it would be better for me to just buy a external cnc controller off ebay such as this one:
https://www.ebay.co.uk/itm/283446744...2494%7Ciid%3A1
im not sure ig I would need anything else such as drivers for the motors? one advantage is that I could input the program off line so no danger of lost steps or pc crashes. I need to get this machine up and running asap so any help would be most appreciated.
thanks all
02-09-2021 #2
That case is mental ?
The Following User Says Thank You to cropwell For This Useful Post:
02-09-2021 #3
02-09-2021 #4
02-09-2021 #5
02-09-2021 #6-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
02-09-2021 #7
You would still need drives for the motors, it's only the controller you'd be buying. Also, if you have two motors on one axis ie twin ball-screws, then I've got a feeling these controllers don't allow motor slaving.? I could be wrong because I don't use or like them as I find PC-based controllers are more flexible and you can see what's happening better, they also allow for far more control of the machine.
They also don't take away the chance of missed steps.? They work exactly like any other controller regards step generation so if you over-tune the motors, which is the most common cause of missed steps, then they will do exactly the same as any other controller and you'll get missed steps.!
They will also still crash because it's still essentially a PC inside that's running the show, but yes they are slightly more stable than a PC that's been used for several other tasks. However, if you do a fresh install of windows on a PC, turn off all the crap running in the background and just use it solely for the CNC with a decent motion controller then you won't get crashes.-use common sense, if you lack it, there is no software to help that.
03-09-2021 #8
I would guess that is little more than a GRBL based Arduino with a fancy graphics interface, still good enough for the job, especially if there is a buffered motion controller built in rather than native step/dir control. I would have to see the setup codes/procedure to be certain. Frankly I am not that interested at the Mo, but I might be if my PC fails to fire up after 2 years of down time.
EDIT - Having looked at the spec of the DDCS3 (or whatever) it is based on an ARM9 32bit RISC chip, this has been obsolete for a few years now (about 15 I think). There must be newer, better and possibly cheaper controllers out there.Last edited by cropwell; 03-09-2021 at 12:21 AM.
06-09-2021 #9
Thank you everyone for you advice and comments (even the c~~ty ones lol. I think im going to bit the bullet and give the duet a go.
I shall report back with a fresh thread on how things are going.
Cheers everyone :-)
08-09-2021 #10
Hi Ravi,
If you could squeeze it into your budget which I guess is very limited, there has been plenty of discussion on this forum about the AXBB-E Ethernet Motion Controller, which you should find with the appropriate forum search.
Good luck, Andy
Speed control option for a dc motor that is not part of a CNC, and eBay controller.
By suesi34e in forum Motor Drivers & ControllersReplies: 3Last Post: 02-09-2021, 11:08 PM -
Boxford Duet “HELP”
By Charles Andrews in forum Lathes, Lathe Rebuilding & ConversionsReplies: 6Last Post: 13-07-2020, 05:38 AM -
Workbee with Duet 2 wifi and planet cnc
By ravihotwok in forum Control Hardware & SystemsReplies: 9Last Post: 20-06-2019, 09:26 AM -
FOR SALE: boxford duet
By reelman in forum Items For SaleReplies: 8Last Post: 05-09-2016, 10:17 AM -
FOR SALE: Boxford duet for sale - no software-
By FarrerDesign in forum Items For SaleReplies: 1Last Post: 13-06-2013, 05:41 PM
