Thread: Back Again
02-11-2021 #1
Hi all
I trust you are all keeping well?
I have not been doing anything at all in the workshop over spring and summer, but now that the nights are closing in, it's time to get back in and get on with my project.
So.............................
At risk of offending some, raising some eyebrows, I am back to get on with my build :smug
It's going to be bad, not pretty and possibly downright ugly and useless
I finally decided what to do and ordered a plate kit from the US to fit my profiles
The 16mm rail kits I purchased will be sold at a big discount to get rid of them and order some 12mm linear rails to fit the plate kit and my aluminium profiles.
Will probably be well into December before everything arrives, I may even have it running for early next year?
Well, it's a plan, it's a start, so here goes
WoodKnotCarpe Diem
03-11-2021 #2
Good luck and welcome back. I actually thought you were ready and forgot all about us. Anyway, hopefully you learned something from the discussions before and not made the same mistakes and miscalculations. One thing though... I still think you would have been better off with the 16mm stuff and the 20mm rails and should have let Jazz fix your issues, even if you'd had to pay for some of his services. 12mm rails are in my opinion too weak for a CNC. I think you will not get the rigidity you hope for.
In any case, ugly or not, it does no matter unless you make it for selling. One of the beauty of DIY is that it's OK if it looks like it was "home made" by amateurs, not factory made by professionals. If it works, it works. The beauty of things can also be the fact the "I made this..." so you can be proud of it, even if it is not winning a beauty contest. Making it useless is in my opinion worst, especially after all this fuzz about it, and especially in the second round. Hopefully you will be able to use it somehow, but my guess is that it will take a long time before you can make your first cut. Waiting for the parts is just the beginning of the process. In the meantime, you can start designing the electronics and all the rest.
03-11-2021 #3
12mm rails are going to be a bit of a sticky subject, what is your intended use/material etc. Normally those size rails you would find on a 3D printer which Is under very light axial/radial loads. Have you got a 3d design drawn up that we all could see?
Rob
03-11-2021 #4
Thanks A Camera, it will be what it will be.
It's looking pretty already
WoodKnotCarpe Diem
03-11-2021 #5
Now then, erm plans. No!
I m kind of flying by the seat of my pants
Well, I am using someoe else's build from openbuilds
I have been told many times its not up to the job!
These builds based on oozenests workbee.
But, for some it may be of interest and some may not?
It may turn out OK, it may turn out to be awful?
WoodKnotCarpe Diem
12-01-2022 #6
hello all
Just like to say that my CNC machine has been a complete success - knocking signs out for fun!!
Easel software is great and I have not broken a single cutter, is very intuitive and easy to use.
Openbuilds Blackbox controller has been a dream to use with no issues what so ever.
So, all in all, very happy with the whole package!
It may not be a commercial grade machine - but it does what i want
WoodKnotCarpe Diem
The Following User Says Thank You to WoodKnot For This Useful Post:
13-01-2022 #7
How about some pictures please?
Bring Back "Back of a Fag Packet" Designs
By magicniner in forum General DiscussionReplies: 9Last Post: 19-04-2016, 09:49 AM -
How would you fasten back to back carriages?
By CharlieRam in forum Rails, Guideways & BearingsReplies: 10Last Post: 04-09-2014, 11:01 PM -
NEW MEMBER: Getting back into it...
By mozzbo in forum New Member IntroductionsReplies: 0Last Post: 30-04-2014, 08:47 PM -
angular contact bearings - back to back, further apart
By dsc in forum Linear & Rotary MotionReplies: 16Last Post: 05-01-2014, 10:59 PM -
Hi All, I'm back!
By irving2008 in forum General DiscussionReplies: 6Last Post: 11-04-2012, 10:01 PM
