Page 3 of 8 FirstFirst 12345 ... LastLast
  1. #21
    This is what i have, what do i need and what do i have to take out....cheers
ID:	30856Click image for larger version.
ID:	30857Click image for larger version.
ID:	30858Click image for larger version.
ID:	30859Click image for larger version.
    Just received my AXBB-E and i also got a 5v and 24v psu so all i need to do now is panic as i dont have a clue what im doing......Help
ID:	30861 do i keep this board as it has the X Y Z axis attached
    UPDATE.....Have connected Axbb-e to the 5v and 12v power psu and also connected network, so now need to build a bigger controller box so all will fit in.
  2. #22
    Quote Originally Posted by mrmacca View Post
    That is an all-in-one board with controller and motor drives combined so you can't use it because you can't control the drives.
    To use with the AXBB-E you will need separate drives.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  3. #23
    Cheers Jazz ...will have a look about and order some.
  4. #24
    My stepper motor has this on it NN MOTOR 57HS7416-15-14B 80 Does that mean anything , when I did a search it didn't come back with much except nema 23, so do i order drivers for a nema 23.
    Depends on what you want to do and the motor spec. Model number not showing anything so double check you have it right.
    What are it's dimensions, that may also give us a clue on it.
    Personally, I never run my nema23 motors below 60vdc anymore which requires the nema34 drivers DM860T instead. The velocity you can achieve is so much better.
  6. The Following User Says Thank You to dazp1976 For This Useful Post:
  7. #26
    This is typical of Chinese machines as they fit oddball motors which you probably won't find any info about. However, doesn't really matter too much because you will only have at best 36Vdc from the PSU so any drive with a 50Vdc max rating will work for you. Because you can't tell the motor current a little trial and error will be needed on the amps but this is no big deal as they will just run hot if too high and stall easily if too low.
    These will work fine for what you need and will work miles better than what you had before. But before buying it's worth checking the voltage coming from the PSU
    https://www.omc-stepperonline.com/di...or-dm542t.html
  8. #27
    Ordered. Cheers
  9. #28
    Ordered. Cheers
    If you find that your max velocity is below what you would like, swap out the 36v for a 48v.
    I'd have gone for the DM556:
    https://www.omc-stepperonline.com/di...scription=true
  10. The Following User Says Thank You to dazp1976 For This Useful Post:
  11. #29
    I use DM542T drivers at 36V on a pair of 3NM NEMA23 motors to pull an 800mm wide welded steel gantry with a 2.2KW spindle on it. It's fairly weighty but will rapid at over 10/min with reasonable acceleration so they'll probably do.
    However, there is always a case for spending a bit more on something over-specified for your present needs if you might want to upgrade other parts in the future. It's a balance between spend more now to save in future.
    To get a bit more info on the motors you could look at the spec of similar sized motors from stepperonline and others. Measure the winding resistance of the motors you have and look for a match in both resistance and physical size. It's not a guarantee they're the same current rating but will give you somewhere to start.
  12. The Following User Says Thank You to Kitwn For This Useful Post:
  13. #30
    Hi All,
    been having a go at building onto the AXXB-E attached are some pics and would like advice as to were I have gone wrong on the stepper drives, also the 3 wires lying by the AXXB-E are from the VFD av1 grnd and +10v were do i attach these to the AXBB-E, also emergency stop and pump.
    All the advice i have had up to now is much appreciated.
ID:	30872 Click image for larger version.
ID:	30873 Click image for larger version.
ID:	30874 Click image for larger version.
ID:	30875 Click image for larger version.
  1. Z axis out by 2mm mach3 or fusion360 problem?
    By Richardtweed in forum Machine Discussion
    Last Post: 01-05-2022, 08:41 PM
  2. Mach3 lathe spindle pulleys problem
    By John11668 in forum Artsoft Mach (3 & 4)
    Last Post: 30-01-2021, 03:04 PM
  3. Small Mach3 Problem
    By needleworks in forum General Discussion
    Last Post: 11-05-2020, 10:46 AM
  4. Mach3 & V-Carve Problem
    By Ricardoco in forum Computer Software
    Last Post: 31-05-2013, 12:53 PM
  5. Mach3 small problem
    By dudz in forum Artsoft Mach (3 & 4)
    Last Post: 15-11-2012, 05:56 PM
