Thread: Help wanted
    Afternoon All
    Not sure if this exisits or not, but i wanted some T-Slotted channel to mount an electric motor and will in turn allow me to tension a chain. I've seen similar stuff in aluminium for wood working tools but dont think it will be quite strong enough as its a start motor that i'm mounting so maybe steel is the only option. To take 6 or 8mm bolts. and about 25mm wide.
    Does anyone know of anything? Need about 300mm of it.
    Looks like this http://www.ptreeusa.com/ttrackproducts.htm
    Brendan
  2. I assume the idea is to slide the motor in the channel to adjust tension? What is the motor fixing, a flange? If so, can you figidly fix one mounting point and use a slotted arm for the other, will be easier to fabricate in ali (unless you are tensioning to several kN, which I doubt)
    yeah i'd considered that and had thought of other ecentric type adjustment as it is flange mounted, the trouble id that the end of the shaft needs to sit in a pillow block bearing, so i thought i could perhaps mount both the bearing and motor on the channel and slide up and down to tension.
    I've been searching all night and other than making a one off bit of channel it looks like too much effort, i've though about making a spring loaded tensioner instead, not quite what i'd like but beggers cant be choosers
  4. How big is the sprocket? Could you mount the motor and pillow block on a plate slotted to clear the sprocket/chain and the edge of the plate rotate on a rod and locked by an arm as before?
    Tom's Avatar
    Location unknown. Last Activity: 30-11-2016 Has been a member for 7-8 years. Has a total post count of 172. Referred 1 members to the community.
    How about unistrut?
    It's ugly stuff (only pressed metal) and not very "CNC", but it might do the job. (it'd fit right at home on my machine!)
    http://www.unistrut.co.uk/index.php?...uble%20Channel
  1. WANTED: Cnc router wanted
    By habibuzziwa in forum Items Wanted
    Last Post: 08-10-2012, 08:47 AM
  2. NEW MEMBER: Cnc machine wanted
    By beneboy1 in forum New Member Introductions
    Last Post: 06-05-2012, 10:56 AM
  3. WANTED: Wanted cnc router!!
    By Signsbelfast in forum Items Wanted
    Last Post: 09-01-2012, 04:59 PM
  4. FOR SALE: Wanted: E-Chain
    By D-man in forum Items For Sale
    Last Post: 26-01-2011, 06:02 PM
  5. WANTED: Wanted taps & die
    By phill05 in forum Items Wanted
    Last Post: 28-11-2010, 12:27 PM
