    Hi all,
    I currently have a Boxford VMC190 which has been converted to Mach4. My problem is the spindle speed is too slow for machining very small parts, I believe it runs at max of approx 2600rpm. I am therefore looking to upgrade to a more rigid machine with larger footprint.
    If you have anything that may be of use please get in touch.
    Regards
    Steven
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 17 Hours Ago Has been a member for 8-9 years. Has a total post count of 490. Received thanks 81 times, giving thanks to others 27 times.
    Have you considered fitting a secondary higher speed spindle alongside, for smaller, higher speed work? A router or high speed cartridge perhaps. I'm not speaking from experience, just observing what others have done.
    I stripped down the current spindle to see if I could up the rpm but never actually thought of adding 2nd spindle.. Shall look into as another option.
    Thanks.
    Muzzer's Avatar
    Here's an example
  5. The Following 2 Users Say Thank You to Muzzer For This Useful Post:
  6. #5
    The 1.5kw spindle looks like it may fit on the side of the head but in the back of my mind I am wondering if I could possibly utilise the original headstock and replace the original motor. It would be interesting to know how good the original bearings are and if they could take the extra rpm.
    Regards
    Steven
  1. Replies: 0
  2. Larger Open CNC Design
    Last Post: 17-07-2017, 04:51 PM
  3. larger stepper motor needed
    By terry1956 in forum General Electronics
    Last Post: 29-05-2017, 05:35 PM
  4. larger home made milling spindles - NMTB/ R8 taper?
    By jonnydeen in forum Tool & Tooling Technology
    Last Post: 13-09-2012, 11:17 AM
