Thread: my first build
Page 3 of 3 FirstFirst 123
  1. #21
    thanks for all the info guys, i think i now know enough about them to order some. going to go with merchant dice as you guys seem to reccomend them. cheers
    All work and no play makes Wires a dull boy:twisted:
  2. #22
    Adrian
    Something else you can look at is aluminum casting, a furnace is cheap to build and you can get some custom components to suite at the same time? look up charcoal furnaces for cheapness and you will be surprised what can be achieved in your own back garden for less than twenty quid and as much scrap ali you can get your hands on?
  3. #23
    i knew this would happen. i wanted to keep this cheap but i have been looking marchant dice online store and i see lots of stuff i like at reasonable prices
    they do hardened high carbon round rail
    http://www.worldofcnc.com/products.asp?recnumber=14
    from reading other threads i think i need 16mm for the bed. they have this...w16 (h6) at 1.90 per 100mm. now i assume that product is 16mm diameter, not sure what the h6 means though.
    also have these http://www.worldofcnc.com/products.asp?recnumber=17
    at 5.40 for the LME16UU i assume that is to suit a 16mm rail.
    they do rail supports as well not too dear.
    now, i am only guessing when i browse all this stuff. all the stuff looks really nice but i am not really certain what to get. i have guessed the above two products and eyeballed a few others, left to my own devices i would probably go with these. am i right in thinking that i can get away with thinner rails in the gantry?
    i am now considering putting off the purchase of the controller/steppers untill maybe february so i can spend some money on these. does anyone know if these guys accept paypal.
    this is all your fault by the way:heehee:
    this is turning out the same as my main hobby, nitro rc racing. i keep getting tempted by nice shiny new stuff and spending a fortune on it, the rc car i currently drive is worth over 1000
    for anyone interested
    xray xb808
    2 x hitec 7955tg
    go tech gx7r
    spektrum dx3s
    any comments on the stuff i am looking at?
  4. Quote Originally Posted by wires View Post
    The h6 is the tolerance on the diameter I believe which is as you surmise 16mm... However these are not supported rail. They will deflect and bounce on long runs and are not really suitable for more than 300mm on a lightweight machine. Although they can be used where accuracy is not paramount, really you need to be looking at fully supported rail. If you want to use unsupported rail you need to be considering 20mm or bigger...
    That is correct, however these round units are hard to use without the matching pillow block
    Yes, but 16mm unsupported rail will deflect 0.2 - 0.3mm with a 6kg router/z-axis in the middle on a 600mm run, so this limits your depth accuracy and surface finish.
    MD accept PayPal, but dont expect fast turnaround... you could be looking at a few weeks based on some recent experience by members... they are a tad overloaded...
  5. #25
    hmm, there is always something. guess they would be fine for the gantry but not the bed. i will still definatly go for the tr12x3 but i will have to have a good think about the linear stuff. this is why i havent cut anything yet. thanks for the info
  6. #26
    i was also looking a the drylin stuff but honestly i am lost in the specs. i have no idea what i need to handle the loads i will have. every time i try to bluff my way through it i get a pretty high price. the bed length will be 1500mm. im sure you guys are sick of answering noobie questions at this stage but does anyone have any ideas on what might suit from drylin?
    i just dont know what to go for, round rail or angular, single or double carriage. or maybe i will just go back to plan A
    Last Post: 08-02-2017, 07:03 PM
