    Hi Guys
    Help Finally got plasma running working great apart from the last 20mm where the cutter turns off, I have tried on 5 or 6 different bits any ideas why please
    retired maintenance fitter Im good with things i can hit with hammer or poke with screwdriver, or even electric glue together but software drives me nuts just cant get head around it
    Thanks Guys
    Acad 2002 drawings
    Sheetcam Post
    home made cnc running mach3
    NVUM v2 bob
ID:	30890Click image for larger version.
    Has the air pressure dropped too low as that could make it shut off ?
    No no matter how big the piece i cut, cut always ends up 16mm short of start
  4. What M-codes are you using to activate/deactivate the plasma? M3/M5?
    Also, what happens if you change the feedrate?
    tail end of code in picture
    will try today to increase feed rate, strange when watching machine speed seems fine but when watching video its so slow to other videos ive wached
    Steve
    It looks like the Z-axis is lifting before the end of the cut so you are losing the arc.?
    Do you have THC.?
    Post the code so can see it and I will try on our Plasma.
    Yes, it's far too slow but that's not the issue.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Do you have THC.?
    Thank you will post in morning its in shed, Im so happy it even moves and cuts but will increase speed, sheetcam is all new to me old head dosnt like taking in new stuff
    No THC just a floating Z
    Do you have THC.?
    Tried at 2000mm min double speed and cut ended at 38mm before start
    gcode from previous 1000mm min run if i can work out how to post eill email it to you
    cheers
    Do you have THC.?
    cheers
    here is a video of running at 2000mm min cut ends 36mm short of start
    https://youtu.be/uNewULWj054
  1. RFQ: RFQ: CNC Woodturning custom hammer handle
    By AndyCD in forum Projects, Jobs & Requests
    Last Post: 08-09-2021, 12:25 PM
  2. Where to find
    By CN-SEE-YA in forum Tool & Tooling Technology
    Last Post: 01-09-2021, 09:51 AM
  3. Felder hammer desktop machine
    By Ollie78 in forum General Discussion
    Last Post: 25-01-2021, 08:27 PM
  4. Help on fault finding on a C3-31 Hammer combination machine
    By OMLCNC in forum Workshop & Equipment
    Last Post: 18-12-2017, 12:58 PM
  5. eBay: Cutler and Hammer (vice?) foot pedal
    By jamesgates1000 in forum Items On eBay UK
    Last Post: 20-10-2015, 07:33 AM
