Thread: Roland MDX-30
06-05-2022 #1
Hi all.
I've had this machine for a week now and just can't get the drivers installed. I downloaded the Windows 7/8/10 x64 drivers and they install fine with the executable and all looks good. I'm using the MDX-40 driver as it's the same engine as the 30. As soon as I plug in the MDX-30 the OS picks it up as an unknown device Roland TS-30. Everything I've read says to update the driver and point it to the MDX-40.inf file to install the correct driver. The problem is that Windows then says that the driver is not a valid x64 driver.
I've even turned off driver signing and tried so many ways to install it that I'm tearing what little hair I have left out. Please help guys.
Thank you.
Sent from my ELE-L09 using Tapatalk
10-05-2022 #2
I've finally sorted the problem with the drivers. It seems that the driver is incompatible with the UEFI file system that has been in use since Windows 7. I didn't know what UEFI was until yesterday but now I do. I had to delete the system partition on my PC then convert it back to the old style MBR (Master Boot Record) system. Then so the system could see it I set the BIOS to boot into Legacy Mode. Then it's plain sailing to install Windows 7, I used Windows Ultimate x64. Once it was installed I connected the MDX-30 via USB and turned it on. Windows saw it and installed it as TS-30 unknown device. Then I extracted the .zip driver file from Rolanddga website into a folder and in Devices and Printers updated the driver to the MDX-40 one. Windows grumbles about it but click Use this driver anyway and all went well.
That's about where I am at now but I have installed Dr Engrave from Rolanddga and sent it to the machine. I didn't set the tool depth but the tool spun and the machine carved out a test pattern in the air above the work piece.
The Following User Says Thank You to Portland Jon For This Useful Post:
06-08-2023 #3
Roland MDX-30
By Portland Jon in forum Items For SaleReplies: 1Last Post: 25-06-2022, 12:09 PM -
FOR SALE: Roland mdx-20
By fcastiglione in forum Items For SaleReplies: 0Last Post: 06-03-2019, 05:45 PM -
FOR SALE: Roland MDX-40 ONO
By Xyz in forum Items For SaleReplies: 4Last Post: 26-06-2018, 08:54 AM -
WANTED: Roland MDX-40 or 40A or SRM-20
By o_drew in forum Items WantedReplies: 2Last Post: 10-02-2018, 10:22 PM -
SOLD: Roland MDX-40 £2,000
By m_christopher in forum Items For SaleReplies: 0Last Post: 22-05-2015, 11:38 AM
