1. i just get a 36v 10a psu and i set it to 24v and it worked ok then i put it to 30v and the chip exploded after about 1 minite it get advertised it runs upto 36v i heard over people had problems with it. The seller only gives 1 mounth wantary with it i e-mailed the seller probally wont hear anything from him.
    Have you got a link to the item?
  3. http://cgi.ebay.co.uk/ws/eBayISAPI.d...:X:RTQ:GB:1123
    here is the link to the controler
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    psu
    and the motors are from zapp ltd model sy60sth86-3008bf
  4. thanks lee
    the controler is over one month old
  5. thats the second of these that went bang... see [ame="http://www.mycncuk.com/forums/showpost.php?p=9250&postcount=24"]here[/ame]
    I think they are unable to cope with the back-emf from a bigger motor and above 30v suffer some catastrophic breakdown... could be the protection diodes are not fast enough...
    Ok i have the predecessor to this (5 axis controller). At best i would not recommend this to run over 24v even with the new chips. There is not enough protecttuion in the circuits for these units. To fix the problem you will need to replace the main ic's. check wit the specs,
    Anything over 24V DC then you are risking popping the driver chips.
    This can be caused by bemf and AC line voltage fluctuation or a combination of both.
  1. WANTED: Tb6560ahq ic
    By Philly in forum Items Wanted
    Last Post: 20-10-2012, 07:12 PM
  2. TOSHIBA THB6064AH Updated Active IC
    By lihaijiang in forum Manufacturer News
    Last Post: 09-04-2012, 02:43 AM
  3. WANTED: Anyone got a TB6560AHQ IC?
    By HankMcSpank in forum Items Wanted
    Last Post: 14-02-2012, 10:13 PM
  4. Heads up, ebay
    By Robin Hewitt in forum Computer Software
    Last Post: 22-08-2010, 05:13 PM
  5. NEW MEMBER: new to cnc having problems with toshiba tb6560ahq
    By elecom in forum New Member Introductions
    Last Post: 25-11-2009, 10:15 AM
