Page 1 of 4 123 ... LastLast
    Hi all, This is my small build. Base is made of structural concrete and the rest is just some steel box tubing for the gantry and some 20mm aluminum brackets and plates. Nema23 3nm closed loop steppers, ballscrews etc...
    Work in progress...
    Hi all,
    New part to upgrade the machine and improve rigidity.
    Hope this video has a bit more quality.
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,914. Received thanks 227 times, giving thanks to others 776 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    Wow machine looks great ...
    ...as do the parts your making, what machine did you use to make those? I will sub and watch your videos later :)
    .Me
    Would you like to share the aggregate ingredients, % of all ingredients and the type of resin. I also want to build , i am almost done with the design but i am looking for proper aggregate now. Thanks !
    Hi Lee, thanks...
    All the parts were made by this machine. It has evolved over the last year... It all started with a 3018 from aliexpress lol
  6. The Following User Says Thank You to XYZ_Spec For This Useful Post:
  7. #6
    Quote Originally Posted by masinecc View Post
    Sure... It's not epoxy resin. It's structural concrete with internal steel reinforcements (the same concrete used in bridges, etc).
    So far so good.
  8. #7
    Quote Originally Posted by XYZ_Spec View Post
    So far so good.
    What min and max sand size ?
  9. #8
    It's already done for you inside the bags.
    Pre-mixed, just have to add water
  10. #9
    Hi Lee, thanks...
    Understood, I went on to watch the vids after I posted, looks good :)
    Still what one did you use the finish looks really smooth, any tricks to that ?
    .Me
  11. #10
    The mix is done with fine sand, that's why the finish is not rough. Applied primer, sanded a bit and then painted it. It's not that perfect, but the performance is what matters at the end. :)
  12. The Following User Says Thank You to XYZ_Spec For This Useful Post:
There are currently 13 users browsing this thread. (0 members and 13 guests)
  1. Damping Test of Concrete & Steel Tube
    Last Post: 16-05-2022, 01:26 PM
  2. Adding a Laser to my steel and concrete machine
    By Bongo in forum Gantry/Router Machines & Building
    Last Post: 16-05-2022, 12:28 PM
  3. Machining lighweight (AAC) concrete blocks.....
    By Voicecoil in forum General Discussion
    Last Post: 03-07-2020, 08:32 PM
  4. FOR SALE: Snowcrete Concrete - 14 x 25 KG Bags
    By Chaz in forum Items For Sale
    Last Post: 13-04-2019, 04:32 PM
  5. concrete base
    By reefy86 in forum General Discussion
    Last Post: 04-12-2017, 09:55 AM
