Thread: Still having problems.
18-09-2022 #1
Hi, I am still having problems trying to set up my lathe. After getting a lot of help on this forum I am getting closer to sorting the problem out ( I hope ) first, I am trying to dial in the motor steps into mach3. After doing the sums, it works out at 1000 steps. I set the motor to this adjust the speed etc. save. Enter the command G0 Z+40, the machine moves 45mm so 5 mm over. Reduce the number of steps to 900. Input the command G0 Z+40 and the machine moves 60mm. Up the steps to 1200 and the machine moves 15mm. This is a closed loop motor. Can anyone please let me know what is going on. Also a few times the motor has not moved at all, until I de powered and started again. Could this be a breakout board problem, it’s just a cheap item off eBay. Thanks
CNC problems
By martythunder in forum General DiscussionReplies: 1Last Post: 15-02-2017, 08:10 PM -
Mach3 Problems problems problems.
By ECCO in forum Artsoft Mach (3 & 4)Replies: 18Last Post: 09-07-2016, 10:07 AM -
F-Engrave problems
By cropwell in forum CAD & CAM SoftwareReplies: 29Last Post: 29-06-2013, 03:48 PM -
problems since update
By motoxy in forum General DiscussionReplies: 6Last Post: 02-11-2012, 06:14 PM -
NEW MEMBER: MDF Problems
By MrWiz73 in forum New Member IntroductionsReplies: 4Last Post: 31-12-2011, 12:39 AM
