Thread: Grounding the machine, electrics
2 Weeks Ago #4
The only thing you should consider when using a multimeter is that the aluminium frame is not a good conductor because of the surface oxide which builds up immediately after cutting through the material. The oxide layer has very high resistance, which can fool the meter, but if you scratch the surface, or wet it a little, it will show low resistance. This is normal, so if the frame is connected to the earth and you want to measure just to be sure, then you must be aware of this.
NEW MEMBER: Newbie to everything, machines, electrics and CNC
By TimGC in forum New Member IntroductionsReplies: 0Last Post: 08-02-2021, 02:05 PM -
Laser Machine Grounding/Earthing
By Want2build1 in forum Laser Machines & BuildingReplies: 31Last Post: 09-02-2015, 10:18 PM -
BUILD LOG: CNC for dummies...Some electrics advice please...pretty please...
By andy586 in forum DIY Router Build LogsReplies: 6Last Post: 01-06-2014, 11:13 AM -
what electrics cnc kit to use for 3x4 cnc plasma
By whensparksfly in forum Plasma Table MachinesReplies: 0Last Post: 27-02-2012, 07:33 PM -
cnc router electrics
By cncroutman in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 24-07-2010, 09:52 PM
