    Hello, i'm just playing about with one of those cheap tb6560 4 axis driver boards from china,
    nothings gone pop yet wich is good but also nothing is happening apart from buzzing from the motors
    i was hoping one of you could give me your opinion on how these should be wired
    the axis conections on the board are marked> a+ a- b+ b-
    heres the diagram for the motorsClick image for larger version.
Name:	nema 23 stepper data sheet.pdf
    i was trying to wire them up bi-polar parallel
    cheers for any thoughts
  2. well if you followed the colour codings correctly then they should work.
    The next thing is are the motors locked...i.e. you cant turn the spindle.. if thats so then the motors are powered so the problem is its not getting step commands...
    What power supply and current settings are you using?
    so then would i wire the blk and the org/wht to a+ and the blk/wht and org to a-??
    and no i can't turn the spindles
    i have just realized my port address may not be normal as it is an expansion card.
    now i've just got to try and work out how to find my ports real address?????
  4. Quote Originally Posted by Dan Brown View Post
    Yes as per diagram 2 on the data sheet... its a little counterintuitive to wire a solid colour and a stripe together but its correct - i have the same motors... But if the motor spindle is locked then thats a good sign! it means at least one phase is powered...
  1. wiring
    By uppy121 in forum General Electronics
    Last Post: 02-04-2013, 05:52 PM
  2. Help wiring M60STH88-3008DF Steppers Motors to 752 Drivers
    By Mad Professor in forum Stepper & Servo Motors
    Last Post: 01-09-2011, 09:09 AM
  3. wiring help
    By deannos in forum Motor Drivers & Controllers
    Last Post: 08-06-2011, 01:20 PM
  4. help me for wiring
    Last Post: 28-11-2010, 12:20 PM
  5. wiring help
    By ste68blue in forum Stepper & Servo Motors
    Last Post: 29-07-2009, 09:23 AM
