  1. #31
    Nearest that I have found is HTS this is for a RPP profile http://www.martinsprocket.com/2001/SecKb.pdf#J74 will do some measurements when I go down to the workshop.
    Peter
  2. #32
    Quote Originally Posted by ptjw7uk View Post
    Peter
    please let us know what u come up with!!
    thanks again tom.
  3. #33
    Tried to measure teeth but the bottom section is radiused about 3mm, so not easy to measure. Taking a resin cast at the moment to to get better measurements. Definately 8mm pitch about 25.6mm wide looking like a HTS pulley might be the one but not found any measurements to caompare to.
    peter
  4. According to Gates, RPP belts will run interchangably on RPP or standard HTD profile pulleys. The main difference it would seem is that the RPP profile has a dent on the top of the tooth to reduce wear and allow the tooth to sit deeper increasing the transmission properties. Are there any markings on the belt itself? Here's a PDF with tooth dimensions for a specific brand.
  5. #35
    Quote Originally Posted by BillTodd View Post
    Export as bmp then use Serif PhotoPlus to convert to JPG
    Or install Draftsight as a freebie.
  6. #36
    Quote Originally Posted by boldford View Post
    2 year ago that mate sure he'd have found something better by now.!
  1. Belt drive on a router
    By John S in forum Rails, Guideways & Bearings
    Last Post: 10-09-2012, 08:39 PM
  2. WANTED: wanted drive belt and pulleys
    By oadamo in forum Items Wanted
    Last Post: 13-05-2011, 08:00 PM
  3. any one know where to get a belt drive convertion for x2
    By Scott in forum Sieg Milling Machines
    Last Post: 27-09-2010, 07:44 PM
  4. Standard Drive Belt Size ?
    By Lee Roberts in forum Belt Drive, Pulleys & Timing
    Last Post: 19-05-2009, 09:56 AM
  5. Re: Standard Drive Belt Size ?
    By HS93 in forum Belt Drive, Pulleys & Timing
    Last Post: 18-05-2009, 02:30 PM
