01-02-2010 #1
Looking for a 2 - 3 foot long transmisson belt, about 1" or so wide, the sort that has 3 or 5 ribs along the length of the belt. Second-hand, as long as not fraying, would do! These are often used as fan/alternator/accessory belts on larger trucks.
03-02-2010 #2
Are you still looking for belts? i've got all sorts of belts the workshop
03-02-2010 #3
yes, i need to replce the leather one on the lathe. the sort I am looking for are like VW fanbelts...5 or 6 ribs about 5mm deep
04-02-2010 #4
Ok I'll have a look tommorow if I get chance. Didnt see the bit about the longitidinadal ribs tho.
I know theres loads of standard of vee belts
04-02-2010 #5
I'm afraid I only have 1 in stock:heehee:
Its 14.5mm wide, 5mm thick overall (2.5mm thick min.) and 740mm ish in lenght or 1480 -1500mm cirfumference, it is aslo a bit cracked/ crazed on the inside. If it sounds any good or at least as a stand by then PM your address and I'll send it up, no charge. If its no good you can throw it away for me.
04-02-2010 #6
worth a go...pm sent
04-02-2010 #7
Those ribbed belts are normally used on alternators on diesel fords and when I mentioned the crazing to my garage they said they last a long time with the crazing so you may get some life from a crazed belt.
Peter
04-02-2010 #8
exactly... it doesnt need a new one.. but 15mm wide might prove too narrow...suck it n see time...
05-02-2010 #9
I'll post it tommorow (or is that later today?
) hope it works...
NEW MEMBER: want buy new or second hand cnc
By buildwood in forum New Member IntroductionsReplies: 8Last Post: 20-10-2011, 05:36 PM -
Low cost 0 backlash transmission - Ball bearing + trapezoidal screw
By LabSkis in forum Lead Screws, Nuts & SupportsReplies: 14Last Post: 26-03-2011, 08:44 PM -
Source for XL timing belts and pulleys
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 20-08-2009, 01:21 PM -
Easy & cheap high amp and volt PSU source
By rinderpest in forum General ElectronicsReplies: 3Last Post: 18-05-2009, 07:45 PM -
FOR SALE: Cheap source for couplers
By progomez in forum Items For SaleReplies: 4Last Post: 19-02-2008, 06:37 AM
