    The DRO on my mill is connected to the sensors by some spiral bound metal cable cover. Could anyone tell me where I can buy this covering as I want to use it to shield the connects from my steppers to their control box. Also I am thinking of buying/making a new control box out of Aluminium (using home made wooden box at present). Can anyone suggest a source, I do not want to use a full sized PC case but a box say 400 x 400 x150 mm would do fine.
    Thanks Alan
  2. Full steel wrap flexible conduit is *******g expensive (~100-200 for 25m) and primarily for mechanical protection. If you want to screen the cables electrically then use a good foil screened cable (also expensive).
    http://uk.farnell.com/pro-elec/61804...25m/dp/1642126
    a cheaper option is metal/plastic (basically a plastic coated spring), again this is primarilly for mechanical protection.
    http://uk.farnell.com/pro-elec/64400...10m/dp/1642134
    If you can use thin cables then this 16mm stuff is not too badly priced (23 for 10m)
    http://uk.farnell.com/kopex/keu0310/...reel/dp/480563
    I thought the consensus was that the cables to the steppers do not need shielding as they are twisted pair!
    Peter
  4. Twisted pairs are far from perfect and don't stop RF interference getting into your device (i.e. from a plasma cutter)
    In the kit car world, shower attachment pipes have been used for cabling (although it's primarily for appearance rather than shielding - but it would have the same effect).
    I've seen 3 for 2m lengths on eBay:
    http://cgi.ebay.co.uk/Flexible-showe...94ab44ffa69507
    Although it does say 4.99 later on - which means for 10m, it would be 25. So similar to the Farnell price...
  1. probing on all metal machine
    By routercnc in forum General Electronics
    Last Post: 06-03-2014, 12:29 PM
  2. Cutting metal shapes
    By jmac80 in forum Metalwork Discussion
    Last Post: 27-11-2013, 09:32 PM
  3. FOR SALE: metal cabinets
    By kingcreaky in forum Items For Sale
    Last Post: 26-10-2013, 04:40 PM
  4. Metal Spinner
    By vueselection in forum Opportunities Available & Sought
    Last Post: 28-05-2012, 02:30 PM
  5. Cabling a CNC Router
    By CraftyGeek in forum Gantry/Router Machines & Building
    Last Post: 20-10-2009, 02:02 PM
