    Hi All
    Wondered if someone could just check my wiring ! , im using Zap 23size motors , 8 wire to a parallel in a Gecko G540 as im finding wiring diagrams confusing ( ive looked at so many , at one time it looked so simple lol )
    http://www.slidesandballscrews.com/p...H88-3008BF.pdf
    Ive wired them up as :
    A = yell / wht
    C = red / wht = A
    A- = yell
    C- = red = A -
    B = green / wht
    D = black / wht = B
    B- = green
    D- = black = B-
    At the moment ive got a green light on the G540 until i plug the motor in then it gose straight to red . So the motors wrong or ive got some more fault finding to do !.
    Fun ahead i think
  2. If you are wiring them bipolar parallel then
    A+ = Red + Yellow/white
    A- = Red/White + Yellow
    B+ = Green + Black/White
    B- = Green/white + Black
    I note the Zapp info lists a blue winding not a yellow one, but assuming the other colours are the same then the above should work...
    Thanks Irving that worked a treat , got to have alook at the diagram to see how i read it wrong ...dohhh!
    Quote Originally Posted by Buba b View Post
    what a find, same drives as I have ......
    I understood the colour of wire selection but not which colours to pair together, anyone care to try and explain a little further
  5. you have 4 windings A1 (red) A2 (yellow) B1 (green) B2 (black). When the motor is used as a unipolar the windings are energised in sequence A1 B1 A2 B2, but in bipolar configuration they are energised in pairs A1+A2, B1+B2. The tricky bit is that the windings are wound as opposing pairs so when used in bipolar parallel arrangement you have to reverse one winding of each pair to align the magnetic fields, hence the pairing of Red with Yellow/White etc.
  6. The Following User Says Thank You to irving2008 For This Useful Post:
  7. #6
    I'm going to print this out and read it beside the wiring schematic, appreciate your reply.
  1. Stepper wiring/colour coding
    By rwb97 in forum Stepper & Servo Motors
    Last Post: 23-06-2014, 10:34 AM
  2. Replies: 1
    Last Post: 16-03-2014, 06:29 PM
  3. Stepper motor tunning wiring
    By handyoodman03 in forum Stepper & Servo Motors
    Last Post: 11-01-2013, 04:49 PM
  4. CY or SY cable for stepper motor wiring?
    By Jonathan in forum General Electronics
    Last Post: 26-09-2010, 05:25 PM
  5. Stepper Motor Wiring (Screened?)
    By pequod in forum Stepper & Servo Motors
    Last Post: 03-08-2009, 09:15 AM
