    Pictures paint a thousand words so to save a lot of reading.
    I want to produce these little port blocks for a Mamod Loco on my CNC Taig.
    Port block is 24.5mm wide and 32mm long. Machined from Brass. I have Vectric Cut3D and V Carve Pro.
    I've exported the drawing as a dxf and can draw offsets for the various machining paths, but what software would generate those for me?
  2. If you contact me and send me the dxf i can get you the g code. Just also send info on you machine so i can set up BobCad/CAM to plot the g-code for it. Heck give me a good drafting set of drawing and I could set it up for you to cut on your machine easy. It all depends as far as g-code generators. I believe that V Carve will do it but have NO experience with V Carve.
    Michael
    VCarve pro will do that with no problem, post the dxf file, the tooling you have / propose to use and I'll talk you thru it.
    John S -
    I've drawn the toolpaths in V Carve, I was thinking there would probably be a better system or software for machining the part though. I wanted to machine a number of these from a length of bar, drill the various holes, saw them to length and then flip them over into a fixture, machine the rear of the port block and machine the steam paths on the block.
    In V Carve I've defined the areas to be surfaced, added pockets, I was planning to machine the part using a 6mm diameter endmill, just using 2.5D machining.
    Sounds OK, it is a 2.5D part anyway.
    John S -
  1. Some Gcode generating programs
    By Jonathan in forum Programmers Corner
    Last Post: 28-02-2014, 06:58 AM
  2. Replies: 2
    Last Post: 11-12-2012, 11:58 AM
  3. FEA Software
    By routercnc in forum Computer Software
    Last Post: 02-10-2012, 12:10 AM
  4. best software
    By k2me in forum CAD & CAM Software
    Last Post: 23-06-2011, 01:55 PM
  5. stl to toolpaths
    By Robin Hewitt in forum Computer Software
    Last Post: 18-09-2009, 11:22 PM
