    Just wondering if it's possible to grind a bog standard drill down to make a flat end mill.
    I only need the end mill to cut acrylic, but I need some odd diameter sizes that are (seemingly) only available as drill bits - so that got me thinking....when is an end mill a drill & vice versa!
    So for the purposes of cutting acrylic...is turning a drill bit into an end mill do-able?
  2. Yep, It sure is, if you have access to a book called the Amateurs Lathe by L.H.Sparey, it tells you how. As far as I recall, you must grind the drill flat, and the allow some backing off on
    the trailing side. And to avoid snatching, it might be advisable to just take the "hook" from the cutting edge by means of an oil stone, this will alter the cutting rake, and make the drill less prone to snatch. As there is no offset in the centre of the drill -as for example in a slot drill.- you may not be able to take plunge cuts. Well worth a try, but practice on some old stuff first.. Hope this can help
    Keith
    i2i's Avatar
    a dremel with some cutting discs is a very usefull tool for shaping the end geometry of drills, and you can get the all important clearance groove with it.
    Quote Originally Posted by i2i View Post
    Well I have a Dremel (actually a Proxxon but same thing). I also have a minilathe...so I was initially thinking to secure the drill bit in my lathe's collet chuck & attacking it at an angle with my Proxxon (bestowed with a cutting disc) mounted on the crosslide
    i2i's Avatar
    you could mark off the chuck in degrees to give an idea where to go to.
  1. FOR SALE: Axminster RF40 mill/drill 3 axis dro, Base and extras
    Last Post: 04-08-2013, 10:30 PM
  2. NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
    By AGB in forum New Member Introductions
    Last Post: 06-02-2013, 03:16 AM
  3. WANTED: Small CNC Drill/Mill
    By Mad Professor in forum Items Wanted
    Last Post: 03-09-2010, 01:28 PM
  4. Help with drill-Mill conversion
    By Ross77 in forum Milling Machines, Builds & Conversions
    Last Post: 02-04-2010, 10:25 AM
  5. Drill/Mill Spindle brake (RF30)
    By BillTodd in forum Machine Discussion
    Last Post: 04-11-2009, 12:09 AM
