Thread: help please with first attempt
30-05-2010 #1
Looking for some help and guidance.
This is my first attempt at building a cnc 3 axis controller, I built the power supply and have attained 28vdc output, I purchased a System 4 motherboard and 3 drv25 driver boards, connected to sys4 m/b and get the Blue power light on, 2 Red lights that fade out, and a Yellow that is on all the time.
Each axis board has 4 dipswitches I have them set to 1/8 step and 2.5A.
Next I connected the motor wires 8 in total, green & black with white stripe are joined together, as are blue & white with red stripe joined together, 4 single wires left Red, White with blue stripe test out as a circuit, and have been connected to 1A & 1B on drive, Black, Green with white stripe test out as a circuit, and have been connected to 2A & 2B on drive.
Next to Mach3.
Set up Mach3 as per PDF details and driver test reports excellent, pulses 24840 -25141
Configs port as should be, x axis enabled, dir active low checked, step active low checked, X axis Motor steps 200, Velocity 2300 all saved as should be.
Next g-code a straight line 200mm long mach3 shows X axis running but motor not turning, can anyone help me, tell me how to test this out and get it working please.
Regards Phill
Plasma Attempt #2
By Robin Hewitt in forum DIY Plasma Build LogsReplies: 21Last Post: 02-09-2012, 08:05 PM -
ok, first attempt using sketchup 8
By deannos in forum Gantry/Router Machines & BuildingReplies: 89Last Post: 25-08-2012, 03:00 PM -
BUILD LOG: My first attempt.... 8 x 4
By trounce in forum DIY Router Build LogsReplies: 0Last Post: 18-10-2011, 11:31 AM -
BUILD LOG: My First Attempt Of A CNC
By AdCNC in forum DIY Router Build LogsReplies: 61Last Post: 21-10-2010, 03:55 PM -
FeatureCam - first attempt
By HiltonSteve in forum CAD & CAM SoftwareReplies: 0Last Post: 01-09-2009, 07:46 PM
