Page 3 of 3 FirstFirst 123
  1. #21
    Thanks guys.
    @ irving2008
    It will be an all MDF machine. Do you think there will be deflection in that section? its only 200mm x 150mm square rom top to the V bearing line. But I'll put that in mind and incorporate a provision for some kind of reinforcement in that section.
    @ John S
    There will be support bearings at either sides of the big pulley and another 2 at the ends of the shaft. What I has me worried about is the Y lateral support (where the X motor's located). Do you think it will still provide rigidity as it is now divided into two to make room for the belt tot pass thru?
    Again guys thank you very much.
    JOrdan
  2. #22
    Quote Originally Posted by j2sip View Post
    Why are you putting it in the middle rather than at one end?
  3. #23
    Hmmm, another great idea from the good people of the forum! It's worth a try. Actually, it's what I'm gonna do. Why didn't I think of it? it will lessen the umber of support bearing o be use. Ill update my drawings. Thanks again!!!
    Jordan
  1. Timing Pulley/Belt sizing software
    By m_c in forum Computer Software
    Last Post: 12-04-2014, 02:33 PM
  2. 1:1 ratio - pulley sizes
    By dsc in forum Belt Drive, Pulleys & Timing
    Last Post: 12-04-2014, 12:30 PM
  3. pulley center distance vs. belt tension
    Last Post: 13-01-2014, 09:48 PM
  4. Where can i find belt and pulley for a spindle?
    By JW1977 in forum Marketplace Discussion
    Last Post: 12-11-2013, 07:03 PM
  5. AC Motor upgrade - pulley sizes
    By birchy in forum Linear & Rotary Motion
    Last Post: 21-06-2013, 09:49 PM
