  1. I finally found some time to start the construction of a new 4 axes CNC router.
    The characteristics are as follows:
    Dimensions (active): XxYxZ 84x43x12 inches, (2100 x 1100 x 300 mm)
    Rolled C7 Ballscrews on all axes: Ø25x10mm (x2) on X; Ø25x5mm on Y; Ø16x5mm on Z.
    Linear supporter round rails Ø25 on X and Y, round rails Ø30 on Z, all with linear bearings.
    Aluminium profile structure, 90x90 mm, heavy. Support assembly made of steel rectangular profile steel 80x80x4, on castors and support bolts.
    Stepper motor driven, NEMA 34, 12Nm.
    Suhner 1050W spindle with ATC.
    The A axis will be a H/V 6 inches dividing table.
    Computer: Atom 330 (dual core), 80GB HDD, 2GB RAM.
    I bought most materials from Zapp Automation (slides, ballscrews, supports for ballscrew, stepper drives and motors - thanks Gary and Therese), KJN Aluminium (aluminium profiles and connection elements - thanks Tina), Damen CNC ("A" axis - thanks Kevin and René) and Sorotec - Germany (spindle and ATC).
    Please see some images below...
    Computer simulated structure:
    Steel support table:
    Aluminium structure:
    Structure assembly (detail):
Name:	detaliu structura.jpg
    X axis (one side):
    All axes (back):
    Z axis (no spindle):
    Y and Z axes (back):
    Y and Z axes (with spindle):
    Electronics box:
    Screen and keyboard:
    First test (axes Y and Z):
    Unfortunatelly, I will have to wait another month before finalizing the construction.
    Any suggestions or questions are welcome!
    Many thanks,
    Florin
  1. Wood cnc router for hobbyist
    By nerostjames in forum Machine Discussion
    Last Post: 01-01-2018, 09:28 PM
  2. wood sign cut with cnc router
    By jonm in forum Woodworking Project Showcase
    Last Post: 09-06-2014, 08:05 PM
  3. BUILD LOG: Wood router machine, 600x400
    By troyboy1 in forum DIY Router Build Logs
    Last Post: 05-12-2012, 12:47 AM
  4. BUILD LOG: Wood Router
    By Buba b in forum DIY Router Build Logs
    Last Post: 03-10-2012, 09:49 AM
