22-06-2010 #1
Ok, so I want to fit a 100mm 4-jaw (as used on minilathes, 20mm central bore) with mounting holes in the back, to a SOBA 4" rotary table with 3 x 120degree t-slots and an MT2 central taper.
One option would be a backplate screwed to a MT2 arbor. I suppose with the table horizontal this wouldnt need a retaining bolt on the rear of the table (otherwise that would prevent the table being bolted down to the milling table without some spacers in between), but might need one when the table was vertical?
I looked at the way RDGTools/Chronos do it but they fit a 80mm chuck to a 100mm plate and therefore there is room to have bolts round the outside, or they use a front-mounting chuck and I want to use what I already have..
Thoughts?
Diy 4th axis rotary table using 100mm chuck with minimal backlash
By kingcreaky in forum Linear & Rotary MotionReplies: 3Last Post: 05-09-2013, 01:03 PM -
Mounting motor under table?
By Rogue in forum Linear & Rotary MotionReplies: 51Last Post: 16-04-2012, 04:02 PM -
Which chuck to fit 6" rotary table??
By wiatroda in forum General DiscussionReplies: 19Last Post: 10-08-2011, 08:47 AM -
Rotary Table CNCing
By irving2008 in forum Gantry/Router Machines & BuildingReplies: 21Last Post: 19-02-2010, 11:57 PM -
Setting up work on the rotary table
By irving2008 in forum Machine DiscussionReplies: 6Last Post: 09-01-2010, 10:27 AM
