Page 4 of 5 FirstFirst ... 2345 LastLast
  1. #31
    No output to the A axis either put it in slave mode over Xaxis and still no running f both axis.
    Checked for continuity on tracks to IC U4 74HC541 line driver chip might be faulty?
  2. hmmm... does Z work?
    It would be very unusual for a chip to fail, these line drivers can take a lot of abuse. You could unplug the BoB from the PC and exercise each pin 2 - 9 to ground and to +5v with a bit of wire and check the voltage at pins 2 - 9 of the HC541 and the matching outputs 18 - 11 and see that they are as expected.
    Its def an HC541?... you've not got the 541 and 244 swapped over (which would give exactly those symptoms i.e. 2 work, 2 dont)
    Irving...
  3. #33
    Yep Z and Y axis ae fine.
    Quickets way to find out is replacing the chip,Irving as they'e only pennys to buy.
    Will let you know in a dy or two how I get on with it and inform you as to whether it was the chip.
    For now I've neglected other work messing around with this and I'll tackle that work till I nip down the towny for a replacement chip.
    Many thanks for your help and those who chipped in,appreciated
  4. #34
    Got another problem,since I know the Z and Y axis work I've been having a dabble to try and get to know MAch3 functions and how it works.
    However in the Motor tuning setup I cannot get anything out of the motors,they jut won't turn....they work fine if I load a G-code.
    Going through the PDF of how to set up Mach3 and this is the first thing it explains to do but it ain't happening for me :cry:any ideas?
    Thank yer vey kindly
  5. #35
    Dang! hold the front page chaps...I reread the PDF and must have overlooked the part where it says "Now press the up&down key on the keyboard"
  6. Quote Originally Posted by GeorgeD View Post
    Ummm, think i said that in post #30...
  7. #37
    So you did Iving,:heehee: I gotta blame it on her indoors,she keeps me awake half the night :naughty:
  8. #38
    Success,seems it wa the chip after all.
    I got a couple at 30p each and also the other type as well.
    Good job I put them in DIL sockets rather than directly slodered. :-)
  9. good to know you're "on the move"... glad to help
  10. #40
    Magic,Iving.
    Is it normal for the motors to make a noise(not operating)when not in use ie no pogram running for their use?
    Thanks.
  1. BUILD LOG: 1250 x 1250 cnc router (from scratch)
    By Danielroyal25 in forum DIY Router Build Logs
    Last Post: 08-08-2014, 06:35 PM
  2. BUILD LOG: starting from scratch- router 1st project
    By idefix in forum DIY Router Build Logs
    Last Post: 09-01-2014, 11:53 PM
  3. NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
    By AGB in forum New Member Introductions
    Last Post: 06-02-2013, 02:16 AM
  4. Starting from scratch, what would you use as a base for a CNC metal lathe?
    By m_c in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 23-01-2011, 04:37 PM
  5. Building from Scratch or follow some plans?
    By Monk in forum Gantry/Router Machines & Building
    Last Post: 12-08-2010, 09:27 PM
