Page 26 of 35 FirstFirst ... 162425262728 ... LastLast
  1. #251
    i2i's Avatar
    Lives in Cardiff, United Kingdom. Last Activity: 30-08-2018 Has been a member for 9-10 years. Has a total post count of 693. Received thanks 30 times, giving thanks to others 0 times.
    basically the motor has 200 steps per revolution, if the pitch of the ballscrew was 1mm and the screw was directly driven by the stepper, then one revoultion of the stepper would give you 1mm set at 200 steps. But if the pitch was 2mm then it would have to be set at 100 steps to give you 1mm movement. It gets a bit more complicated when the stepper drives the ballscrew through a toothed belt and two different sized pulleys, as in the boxford. So to get back to the 1mm movement for one revolution on a 2mm ballscrew you would have to gear the motor down by 2:1 at 200 steps.
  2. #252
    Blimey sorry about that i dropped off to sleep there :) Ok so if i find out the pitch of the screws and the gearing of the steppers i will be ready to set this information in mach... I will get on that first thing tomorrow morning, That should be fun lol..
    Rick
  3. #253
    MHJ's Avatar
    Location unknown. Last Activity: 13-01-2013 Has been a member for 6-7 years. Has a total post count of 4.
    Morning.
    Mine is set up like this:
    Motor Tuning and setup
    X steps per = 1000
    Velocity = 1200
    Accelleration = 500
    Step pulse = 5
    Dir pulse = 0
    For the Y: the same
    For the Z:
    Steps per = 1000
    Velocity = 1200
    Accelleration = 500
    Step pulse = 5
    Dir pulse = 0
    For the spindle:
    Steps = 200
    Velocity = 600
    Accelleration = 1000
    Step pulse = 5
    Dir pulse = 0
    And in the Pulley Selection:
    Pulley 1
    Min speed = 0
    Max speed = 2000
    Ratio = 1
    Hope this helps,
    Regards,
    John.
  4. #254
    Quote Originally Posted by MHJ View Post
    Morning.
    X steps per = 1000
    Velocity = 1200
    Accelleration = 500
    Step pulse = 5
    Dir pulse = 0
    For the Y: the same
    For the Z:
    Steps per = 1000
    Velocity = 1200
    Accelleration = 500
    Step pulse = 5
    Dir pulse = 0
    For the spindle:
    Steps = 200
    Velocity = 600
    Step pulse = 5
    Dir pulse = 0
    Pulley 1
    Min speed = 0
    Max speed = 2000
    Ratio = 1
    Hope this helps,
    Regards,
    John.
    Thanks John, I suppose the first question for you is do you have a 260vmc? and are your ball screws and steppers standard? and if so what is the pitch of your ball screws? and what is the stepper to lead screw gearing?, Inquisition out of the way its nice to have the details you posted as i would like as much information in this thread about these machines as possible, the reason I started the thread is because so little information is available on the net About it.
    Every little helps as the woman said when she ........... in the sea!!
    Rick
  5. #255
    MHJ's Avatar
    Those are the settings for my Boxford 260 VMC. They should get you up and running.
    Ball screws and stepper motors are standard. As to your other questions, I'll dig through my archives for the information....I have of course no memory left after the Denford Easiturn3 conversion, which I finished yesterday. (Don't mention that though, because I've spotted a job list drawn up by the Domestic Engineer.) If you want the other Mach3 settings I use, just shout.
    Regards,
    John.
  6. #256
    i2i's Avatar
    Hi John, what drives are you using for the steppers and spindle (analogue voltage), and what mode for the steppers.
  7. #257
    Regards,
    John.
    Have you got a saved mill profile?
    Thanks John.. :)
  8. #258
    i2i's Avatar
    Rick, have you got the drives running?
  9. #259
    Oh yes all axis duely played with!!!!
  10. #260
    i2i's Avatar
    ok, so what are the steps set at in motor tuning and if you move an axis 1mm what does it actually move.
  1. The Boxford 260VMC as you probably never seen it before!
    By rnr107 in forum Boxford Vertical Mills
    Last Post: 15-02-2018, 08:47 PM
  2. Boxford 260 VMC
    By shoeswith in forum Boxford Vertical Mills
    Last Post: 10-04-2017, 05:20 PM
  3. boxford vmc 300
    By bigred5765 in forum Boxford Vertical Mills
    Last Post: 22-04-2014, 03:22 PM
  4. Boxford mt2
    By Hellfire in forum Boxford Lathes
    Last Post: 03-08-2012, 07:46 AM
  5. Boxford 160 TCL
    By Brinner in forum Boxford Lathes
    Last Post: 31-03-2012, 08:11 PM
