    Trying to drill a series of 3 or 4 holes in a spanner shaft without any joy
    The spanner is dropped forge steel and the HSS bits have just about scratched the sufacelol
    Any ideas to get me out of a pickle?
    This spanner is pemanently located under my router table in a manner it will be withdrawn from the collet nut and fed onto the nut when needed but I need to cut/drill a cutout in the shaft for it to go on the arc slide here.....
    A carbide bit will drill through a file if you don't mind a few red hot sparks, or you could draw the temper or you could weld a tab on the side then drill that.
    Nice one Robin,think thats the most easiest option as I don't have carbide bit.
    Just use a masonry drill. plenty of pressure when done bin it.
    Peter
    This is what I use when I come across a tough job.
    http://www.leofixings.com/fixings-pr...ts-10-132.html
    This is also the place I get most of my drills, nuts, bolts, washers, in fact lots of things. I doubt if you will find cheaper for such quality, and yes, you can get a thousand screws for a couple of squid. Much cheaper than B&Q.
    Bogs
  1. taperlock fit on a shaft - h5 / h6 ?
    By dsc in forum Machine Discussion
    Last Post: 03-09-2013, 08:09 PM
  2. 6mm shaft to 6.35mm hole?
    By JuKu in forum Metalwork Discussion
    Last Post: 15-12-2012, 01:29 PM
  3. shaft - grinding part joint
    By dsc in forum Linear & Rotary Motion
    Last Post: 21-11-2012, 08:31 AM
  4. Stepper shaft couplings - can you ID these?
    By HankMcSpank in forum Stepper & Servo Motors
    Last Post: 15-04-2012, 02:46 PM
  5. Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
    By LoveLearn in forum Gantry/Router Machines & Building
    Last Post: 08-02-2012, 12:52 AM
