05-08-2010 #11Very true that Boggy.
No need for a big rod then.
Was going to email the bloke and ask him where he found his big rod. lol
http://www.mycncuk.com/forums/attach...2&d=1237608237Last edited by BillTodd; 05-08-2010 at 09:15 PM.
05-08-2010 #12
I just use a DTI?
06-08-2010 #13I just use a DTI?
06-08-2010 #14
I was wondering what I was missing. Why pop the centre and use a pair
of centres when you can use a DTI? I have a few minutes I will set up a bit
of square and try and make a video if anyone wants to see it.Last edited by graffian; 06-08-2010 at 06:43 PM.
06-08-2010 #15try and make a video if anyone wants to see it.
06-08-2010 #16
I set up a chunk of square, actually took longer to find a bit than
to set it up. The video is really crappy, I know what's going on cos
I was there;-) Holding a camera and doing something is too difficult
for me.
06-08-2010 #17
You should aquire a tripod then.
06-08-2010 #18
I did try with a tripod, the lathe has a window behind it and all you could see was the sillohette of the gauge;-)
What it needs is a flexible, but lockable, arm to mount the camera on.
Seeing the marking on a DTI isn't easy if the picture shows much of whats going on. I did a video of a gear that
had runout, to show the people who supplied it, I used a 4" face gauge so you could see it. I don't think I can use
the big gauge to set a square as it probably won't clear the corners.
06-08-2010 #19
So your using the corners as a means to centralise the block?
06-08-2010 #20
Moving the corners would be to complicated for me;-) I set up the flats.
Auto Square the gantry
By D-man in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 19-10-2014, 06:07 PM -
Square Ballnut??
By Ricardoco in forum Gantry/Router Machines & BuildingReplies: 19Last Post: 29-06-2012, 10:32 PM -
WANTED: 10mm think square of aluminium?
By Tenson in forum Items WantedReplies: 2Last Post: 08-06-2012, 12:42 PM -
Getting everything square
By daveshorts in forum Gantry/Router Machines & BuildingReplies: 13Last Post: 31-01-2010, 11:21 AM -
Colchester Student 1800 Square Head Lathe - HELP !
By cncroger in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 03-02-2008, 08:28 PM
