21-03-2011 #1
Hi all I just received a Boxford TLC 125 that I bought of ebay.
Unfortunately somebody has already disassembled the ball screw bearings (luckily not the actual ball nut) on re assembly they have managed to get a really notchy feel in the end bearings. I looked on the boxford website under spares http://www.boxford-software.com/spar...BallScrews.php the description there seems to indicate that I should have a needle roller thrust bearing in the assembly somewhere. However my end block (part TCL-05-012A at the above link) has two deep groove ball bearings pushed into it. Can anybody tell me what I should actually have in there and in what order they go. For instance should I have two ball bearings and the thrust bearing ? should I have two of part BR-AS0619 ?
Any links to drawings or documention would be a great help I recieved absolutely no papaerwork with the lathe.
Regards
Lamestllama
25-03-2011 #2
HI, unfortunatly i cannot answer this quesstion but it would be good to see any drawings of the machine if anybody does have them
There is a company on the tinterweb that retro fits TCL 125 but i havent even herd back from them
25-03-2011 #3
in the larger boxfords they have two angular contact bearings opposite each other to locate the ballscrew in the top plate.
taper roller bearings vs deep groove ball bearings
By dsc in forum Linear & Rotary MotionReplies: 8Last Post: 10-03-2014, 08:06 AM -
bearings and ballscrew dont fit each other
By marbles in forum Lead Screws, Nuts & SupportsReplies: 12Last Post: 09-02-2013, 06:06 PM -
FOR SALE: Vee Bearings.. 16 off un-used...
By fasteddy in forum Items For SaleReplies: 4Last Post: 21-06-2011, 09:01 AM -
Ballscrew Support Bearings - Angular or Self Align or ??
By williamturner1 in forum Lead Screws, Nuts & SupportsReplies: 8Last Post: 02-10-2010, 02:38 PM -
Bearings(Rotary)
By GeorgeD in forum Linear & Rotary MotionReplies: 7Last Post: 14-08-2010, 05:50 PM
