Thread: Hot Foam cutter for RC aircraft
06-07-2012 #21
Looks like a nice project. My 3D printer uses M8 threaded rod, it works surprisingly well considering the price. I have always had doubts about the accuracy, but when printing at a resolution of around 0.1 mm it is not critical. The bigger problem I have is "wobble", although I think that is more of a design issue with the printer frame.
Unfortunately, the price hike to leadscrew is pretty steep. I priced up 4 sets of 10mm leadscrew and it was way too much. I would be better putting it towards a new machine.
A couple of questions: how is the wire tensioned? Presumably it has some stretch to allow for change in distance while it is cutting a profile?
Is there anything special in the software setup to handle the fact you effectively have two X,Y coordinates? My understanding of the GCode machine model is that all axes in a G1 move are synchronised and coordinated, so it does not matter how or where the axes are.
06-07-2012 #22
Hi Bobc
Wire will be tensioned by spring to allow for the x axis on both towers to move interdependently for cutting tapered wings. I'm testing out different software but profili2 pro has 4 axis for foam cutters and foamworks generates the gcode as well.
post some more pics up soon when I have it cutting some foam
Keith
08-07-2012 #23
It works
http://youtu.be/uQk3urqLs5Y
18-01-2013 #24
Hi Guys
Few more updates. I've added home/limit switches and run some test cuts. Its starting to become a bit easier now. Here's a link on my website CNC Config Mach3 and TB6560 with some sample cuts and setup.
I've documented the configuration so anyone else using the same set up can save a bit of time and head scratching.
The biggest learning curve I think is getting all the software to work, but I use Mach3 and profili2 which do good job. I'm also looking at InkScape as there is a gcode extension for it. Might use this to cut fuselages.
Keith
The Following User Says Thank You to rckeith For This Useful Post:
30-06-2013 #25
This video show the flying wing I made with the cnc foma cutter its on my video page RC Video's - rcKeith | Projects
It was a quick test to see how it could cut wings and what a fantastic flyer its is. Its my favorite flyer now. Goes like stink and can fly at snails pace as well.
Have now purchase DevFus software to make fuselages which I going to test on a 50 inch wing span Hurricane.
Keith
10-08-2015 #26
I've added a lot of details to my build including plans, instructions and parts/cutting lists all at my website www.rckeith.co.uk . I've have a video almost ready that should be up in a few days on using Profili Pro 2 for cutting foam wings which I'll then follow up with one on Dev Fus Foam. I've used these to produce a 50 inch Wing span Hawker Hurricane. A few images below. Not finished yet because of other stuff getting in the way. I'm now looking to build a CNC router probably a Openbuilds OX but also may try and build Mark Carew's Phlatprinter this seem ideal for producing foam models. I like the fact its fairly compact and can produce large parts.
Machineable foam
By craigrobbo in forum Marketplace DiscussionReplies: 7Last Post: 03-02-2013, 08:40 PM -
Machining Insulation foam
By Philly in forum Machine DiscussionReplies: 3Last Post: 28-01-2013, 12:38 AM -
CNC Hot Wire Foam Cutters
By HotwireCutter in forum Manufacturer NewsReplies: 0Last Post: 02-05-2012, 09:04 PM -
NEW MEMBER: First post - want to build a cnc hot wire foam cutter
By rckeith in forum New Member IntroductionsReplies: 8Last Post: 12-12-2010, 12:23 AM -
Software for foam cutter - any recommendations
By rckeith in forum Machine Control SoftwareReplies: 2Last Post: 08-08-2010, 10:14 AM
