12-08-2010 #1
I've been wanting to build a CNC Router for some time now to help with building RC Gliders and planes. After much searching and looking on forums I've been recently collecting bits to make a CNC Router. I'm going the "skinflint" way at first to get into it before upgrading/re-designing later once I've had a good play! Bits I've bought/collected so fare are:
- 3 x Nema 23 Mineba Astrosyn 23LM-C355-P6V 1.5A/winding 550g/cm torque Steppers
- 250W 24V 10A Switching Power Supply
- 3 Axis TB6560 Stepper Motor Driver Board Controller
- TR12x3D Trapezoidal Spindles for the X & Y and TR10x2 for the Z Axis
- 6 x V£ type micro switches (limit & home)
- Emergency stop switch
- Delrin for antibacklash nuts (will make them myself from homemade tap)
- Performance Pro 701W Rotary Cutter
- 24V fans for cooling electrics
- 300x20x120 Plastic enclosure for electrics
- Screened Cable for wiring (from Work)
- Armoured cable sheath for running the wires in
- 100x100x19 block of Aluminium for making the router holder/mount
The frame is going to be made from 40x40x5 RHS steel (sourced from the scrap bin at work), the X axis rails are going to be from 1" NB CS Sch40 pipe (again from the scrap bin) the Y & Z rails from 3/4" NB Sch40 CS pipe (scrap bin raiding again!!) The bed will be 18mm MDF. The Y Axis sides and frame are going to be from either 5mm steel or 10mm Aluminium. I'm going to use skate bearings for the runners, a combination of skate-o-rail (Z & Y Axis) and joes2006 design (Z axis)
I've had the electronics together and working, see => http://www.youtube.com/watch?v=eJ9uujaey-0 so now I'm just drawing up the machine and starting to dimension the parts.
I'm going to make as much as I can. We have a Colchester Bantam lathe and Bridgeport milling machine at work so If I can remember how to use them (it's been over 20 years since I was last in a machine shop) I'll make all the bearing shafts, machine the leadscrew ends and drill/tap all the plates etc.
I've uploaded a PDF of what I've drawn so far (minus all the scrap bits round the side) for you all to comment on. All I want to machine is balsa and ply and possibly some plastic. Not sure it will be up to doing Aluminium so maybe that will be phase 2!
Cheers,
Neil
BUILD LOG: A3 Router Build
