09-01-2015 #401
Quick vid showing the drilling with the guide in place, I've not showed setting up to drill a hole as I'm sure that's pretty self explanatory...saying that so is drilling the hole...oh well
The pillar drill is a bit old and knackered and I think could do with a little TLC....
The Following User Says Thank You to njhussey For This Useful Post:
12-01-2015 #402
Did a bit of shopping on Friday and it turned up today I bought a 1200mm Veritas straight edge, a couple of 6" engineers squares and 4 100mm G cramps.
Placing the straight edge against the rail there was a bow in the middle of the rail of about 3 thou so I loosened all the master x rail bolts and clamped (lightly) the straight edge to the rail in 6 places. I then tightened the bolts checking with a feeler that there was no gap between the reference side of the rail and the straight edge. Once this was done I placed the straight edge on the reference side of the rail and tried the feeler gauge again. It was the same all the way down with no gaps so I'm happy with that. I'm going to clamp (lightly) the straight edge to the rail again and then one by one take out the M5 socket cap heads and threadlock them in. This should give me my master reference X rail to set the second X axis rail from.
I wanted to see if there was/how much twist there is in the rails. Placing the straight edge across the two rails on top of the carriages I tried to get a feeler gauge underneath the edge and couldn't. Shone a light from the other side and couldn't see a thing so it looks like the epoxy has done it's job in finding the level. Again I'm happy with that!
Waiting on my Tooling plate to come before I square the second X axis rail so I'm just making drawings so I know where I'm drilling holes, machining pockets for steppers ballscrew housings etc, what size belts and pulleys to get etc. etc.Last edited by njhussey; 12-01-2015 at 12:56 PM.
12-01-2015 #403
Quite likely yes - but how much force will bending the bearing to 'flat' impose upon it? The answer is a lot, since the stiffness of these bearings is still very high in the rolling direction. It also depends on how stiff the gantry is and how wide it is - something has to bend. A fairly high force wont make much difference to how smoothly the bearings roll, since as I mentioned in the last post their co-efficient of friction is very low. It will still shorten the life of the bearings though.
It's different with round rail bearings - clearly they have zero stiffness in the rolling direction, so angular misalignment doesn't affect the force of the bearings (within reason).
If you look in the datasheet for the rails and bearings you'll find specifications for the maximum linear and angular misalignment. These are based on getting the rated lifetime out of the bearings, so if you exceed it by a little, the bearings just wont last as long. Though on a home machine it might still outlive you!
That's a good indication that they're close, but since you've got the straight edge you might as well measure it carefully. The issue with what you just did is it's hard to measure very small angles and you don't get a reading for what the angle actually is. Instead you need to do something like in my build log - stick the dial indicator on one of the bearings and mount the straight edge parallel to the rail, but some distance (say 200mm) horizontally away from it. Make the indicator touch the straight edge, with it's movement perpendicular to the surface. That will convert the angular reading into a linear reading and amplify it. You don't need to worry too much about getting the straight edge level, as if you plot the readings on a graph that will just make a linear error which you can subtract.
Just out of interest, how much did the straight edge cost?
12-01-2015 #404
I'm not too worried about the life of the bearings, as you say I'm sure it will outlive me and for what it's being used for. I will measure it though out of interest as I have the straight edge ...
The straight edge was from Axminster http://www.axminster.co.uk/veritas-a...-straight-edge it's got a claimed accuracy of 0.075mm over the 1270mm length which although not super accurate is more than good enough I think for my purposes.Last edited by njhussey; 12-01-2015 at 05:31 PM.
12-01-2015 #405
Picking up Jonathan's comment re stiffness in roll and manufacturer's tolerance...
HiWin 20mm rails have a maximum permitted height difference of 0.130mm with 500mm rail spacing. That corresponds to a difference of 0.013mm across that 50mm or so bearing block. Don't know about you, but that's about a quarter of my thinnest feeler - and that's the maximum allowable tolerance. As for stiffness - and I don't recommend you do this at home as I only did it by accident - my gantry structure probably weighs around 30kg, and I managed to leave it hanging while only attached to the carriage at one end. It probably dropped by no more than 25mm or so. I hate to think of the abuse of the pair of bearing blocks taking the weight, but what's done is done. I shall be reporting on my experiments with epoxy (i.e. mistakes and how I've tried to correct them) elsewhere when I'm actually happy with the results, but in simple terms, it's a lot easier to get the rails level than to remove twist. The main reason to get the rails level (given that you will take out minor variations by machining the spoil board anyway) is that with, say, a 1000mm rail spacing, the max rail height difference spec only allow a height difference of about 0.26mm (10 thou). That's not too difficult with epoxy, and I would expect rather better with just a bit of care. But twist? As long as it is constant, then the gantry to bearing block joint can be shimmed/adjusted to suit but you only need a tiny amount of varying twist to go way out of spec. I'm still trying to get mine somewhere near acceptable. I'm using a sensitive level (0.02mm/m readings) to check.
It would be easy to say that the problem is that I'm chasing irrelevant numbers with tools that are working at their limit, except that a trial bolt-down of rails with gantry mounted gave clear signs of graunching bearings even when I was happy with levels. Suck-it-and-see tells me that there's something wrong.
12-01-2015 #406
These are the NSK specs on running parallelism....seems in theory I have about 16 microns for my 800mm spaced rails to play with....to be honest I think you can keep chasing numbers till you're red in the face and for a router that's going to be used for wood and plastics mostly with some aluminium then I'm not going to get my knickers in a twist about it.
I'm going to do a quick test as Jonathan did (I'm intreagued now) and then once the gantry is made bolt it to the carriages and see what they sound and feel like.
12-01-2015 #407
I bet you wonder how you ever managed without a straight edge now
16-01-2015 #408
Picked up the cut tooling plate just now....gantry build can start next week though first got to design and build a pantograph arm for putting in M6 UNC bolts and grease nipples into 1000 units we're currently assembling for a contract....oh, that's after I've finished machining a custom unit that's just been ordered. Work keeps getting in the way of playing!
20-01-2015 #409
20-01-2015 #410
Looks good software on their website, can't wait to get stuck into that aluminium plate eh !
BUILD LOG: A3 Router Build
