Hi all,
Just starting looking into my options for cutting 0.5 mm sheet aluminium and found this forum and hoping for any pointers.
I have been looking at a Mechanical option rather than laser as I believe that's what is required with a work base of 600mm x 400mm which is about right for me. I don't really require the engraving option as it is just fine(ish) detail cutting of various shapes I require.
Any toughts or advice appreciated.
Cheers,
Andrew
12-08-2010 #2
Welcome Andrew
Are you looking to build or buy?
The first obvious problem is that you will need to cut all the way through in one go so a sacrificial bed will be needed and probably double sided tape to stop it moving once its cut.
I guess you'll need small high speed bits to stop the sheet tearing, with a fairly low run out on the spindle so you dont break them. get that sorted and you should be good to go.
This is just my opinion and there will be those who have used an mdf machine with a dremel and got results.:whistling:
The Following User Says Thank You to Ross77 For This Useful Post:
Holding it is your problem, it's too light.
You could use left hand helix to stop it burring up but you'd have to change the backing about once a sheet.
Have you been put off by a laser quote?
If I had to cut all different shapes, I'd probably start by looking for the smallest available plasma head.
If I had to cut a few shapes repeated, I'd probably get quotes for cutting a stack of 10 or more with abrasive water jet. Don't want to weld it :naughty:
The Following User Says Thank You to Robin Hewitt For This Useful Post:
12-08-2010 #4
Thanks for the initial advice.
As I know hardly anything about this type of thing but it could very well become a key part of our business I was looking at the Vision 1624. Building doesn't even cross my mind unless it is a realistic option. The reason I am looking at mechanical is due to the aluminium being coated with a laquer and didn't want to damage it with laser. If other realistic alternatives are available happy to look. I'd prefer not to spend the amount needed for the above model and even decent second hand would do to get us up and running.
Thanks again.
Andrew
12-08-2010 #5
A laser is that quick it wouldn't damage the coating, we have it cut in 4mm thick and it still leaves the clear plastic sheet intact.
cutting alloy, especially in thin sections with a router is slow, messy and prone to building up on the cutters if not lubricated and that in turn will rip the material out of position.
The sheet thickness you specify is usually in dead soft form which is real gummy for mechanical cutting. the harder grades usually don't come in this thickness.
.John S -
The Following User Says Thank You to John S For This Useful Post:
12-08-2010 #6
Thanks John.
I had a few samples cut out and it came up well on the mechanical engraver. I asked a local trade engraver to do the aluminium and they said the couldn't. Also, Identify in Bristol said no laser. Your making me doubt myself now as I was also talking about cutting frp plastic as well. Hmmmm?
I am looking to get a fair bit of daily use out of the machine so happy to look at any method that you guys think might work.
12-08-2010 #7
Depending on quantity, what about water jet cutting?
The Following User Says Thank You to Peter Griffin For This Useful Post:
12-08-2010 #8
I know nothing about water jet cutting but open to any options. Quantities will range from one per design possibly upto 1000. A bit unknown yet. Some designs are simple whilst others will have more detail cutout.
Abrasive water jet is a very high velocity squirt of water mixed with grit. It will cut through most anything, without heat.
13-08-2010 #10
Thanks again for the help and advice.
An thoughts on what makes or models for what might suit the job? Like I said, the Vision 1624 I was looking at or similar but would prefer to pay less and buy a second one if things go well.
eBay: 8x4 sheet of 25mm thick aluminium plate.
By T0rnado69 in forum Items On eBay UKReplies: 0Last Post: 18-04-2014, 02:01 AM -
Milling Sheet Aluminium
By p1lts in forum Metalwork DiscussionReplies: 8Last Post: 08-03-2014, 12:23 AM -
WANTED: 100mmx100mm 6mm aluminium plate/sheet.
By Isaac in forum Items WantedReplies: 11Last Post: 06-02-2014, 12:11 AM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Aluminium Tooling Sheet - Various sizes
By Fewco in forum Items For SaleReplies: 4Last Post: 16-01-2013, 04:27 PM
