    Hi All
    I need ten or twenty sets of end plates cutting for a project case I am working on.
    Each plate is 27mm by 78mm. One plate needs one hole cutting in it for a subd25 and the other plate needs three holes cutting in it for a usb port, led and small reset switch.
    This is a very light job, the end plates themsleves are supplied with the cases, I just need the holes cutting as above.
    This is the actual case and you can see the end plates.
    http://www.rapidonline.com/sku.aspx?...catref=30-1562
    Please contact me on 07870-903552 or message here with your details and I will call you.
    Carl
  1. RFQ: Require small Stainless steel buckles machining- can you help please ?
    By Gasgasbones in forum Projects, Jobs & Requests
    Last Post: 15-05-2013, 05:47 AM
  2. Need some money making project ideas
    By Fivetide in forum Marketplace Discussion
    Last Post: 23-11-2012, 08:50 AM
  3. Drivers,BOB and PSU are in a PC case, do i earth the case
    By deannos in forum Motor Drivers & Controllers
    Last Post: 27-11-2011, 02:43 PM
  4. PC case control box
    By lateAtNight in forum Electronic Project Building
    Last Post: 02-02-2010, 02:27 PM
  5. Controller box from PC case
    By Smiler in forum Electronic Project Building
    Last Post: 24-12-2008, 02:46 AM
