    Hi All..
    Finally getting down to some fine tweaking... In trying to measure any slop, and I am sure I have some as my X and Y are chain driven, I have been machining some slots 100mm long..
    First I move the X axis in the +ve direction, then machine a slot also in the +ve direction.. Reckon there should be no backlash at this point.. Then I move a few mm across the y axis and machine a slot in the -ve direction of the X axis.. This should, by my reckoning, then show up any backlash and I was expecting the second slot to be shorter...
    But no..! It was 0.2mm longer... Have repeated this several times with the same result..
    And, as always, when I get to scratching my head too much, I pop here to see what silliness you guys can point out that I am doing..
    Steve..
    Hi Steve
    what happens if you zero a DTI next to the machine before it cuts the first slot, then send it away in +ve X to cut the slot, then just come back to the start position again (i.e. cut the slot twice with no Y movement)?
    what happens if you do this without cutting (just jogging away and back again) to a fixed DTI?
    Lost steps? Binding axes?
    Cogging maybe? A chain is moving slightly faster when a roller passes perpendicular to the sprocket axle.
    Okidoki..
    Things to look at.. Things to try... Will try/look at later this afternoon... Thanks guys!!
    Steve
  1. Micro lathe Zero backlash* conversion
    By Jonathan in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 22-09-2012, 09:56 PM
  2. Is this an example of what backlash can do?
    By Minnican in forum Machine Discussion
    Last Post: 06-03-2011, 07:59 PM
  3. backlash mack3
    By h4ppy-chris in forum General Discussion
    Last Post: 29-01-2011, 12:11 PM
  4. Sieg X3 backlash...
    By Vikash in forum General Discussion
    Last Post: 20-10-2010, 01:51 PM
  5. Sieg C3 backlash problem
    By Cret in forum Milling Machines, Builds & Conversions
    Last Post: 08-09-2009, 06:18 AM
