Thread: Missing Steps + Stalling X-axis
Threaded View
26-08-2010 #1
To cut a long story short; I've revived my CNC mill, from being sat on my bench doing nothing for around 9 months because of a damaged spindle.
I got a new spindle custom made for the machine, just fitted it tonight; switched on, booted up, and put the thing into first gear...
However: The X-axis sounded VERY ODD.
Took a closer look, and it is missing steps BADLY + stalling very often.
If I jog X+ and it starts to stall, giving it a little nudge tweak on the ballscrew brings it back into movement.
It does stall/jitter in both directions, but more so in one that the other.
Turning the ballscrew by hand doesn't mechanically feel that sticky; which is what has confused me.
I removed all the bellows, gave it a good clean (not that it needed much) and oiled all the ways and ballscrews. Ran it back and too, to let it soak in. And still the same.
If I send single steps, then it just jitters back and to on either step.
At the highest feed rates (1320mm/min) it doesn't seem to have this problem. Just anything less than this causes the issues...
SO: Is this a "bad stepper" one on it's arse? Or a mechanical issue?
It would be a *MASSIVE* pain in the arse to fully remove the X-axis and investigate in detail, so I'm not jumping to that immediately.
Anyone any ideas?
Cheers,
Dan
clunks / missing steps - DM856 and single pulse operation
By dsc in forum Motor Drivers & ControllersReplies: 37Last Post: 09-12-2013, 02:22 PM -
Y axis stalling
By richie00boy in forum Machine DiscussionReplies: 38Last Post: 11-09-2013, 10:37 AM -
Strange problem, possibly missing steps?
By Philly in forum Chinese MachinesReplies: 5Last Post: 26-10-2012, 06:36 PM -
X and Y axis stalling
By francooz in forum Machine DiscussionReplies: 11Last Post: 05-01-2011, 06:27 PM -
z axis loosing steps
By ptjw7uk in forum Machine DiscussionReplies: 23Last Post: 10-05-2010, 07:38 PM
