    If its the standard number plate font then you can download it free from here - http://www.fonts4free.net/show-font....lick+To+Render
    If its not then let me know and I will see what I have got as I have a few thousand fonts and it will probably be in there somewhere.....
    Just downloaded and tested it....
Name:	John Hobnobs.JPG
    This was done in ArtCam2008.
    Yup works in Vectric
    John S -
    Alright, so I forgot the S........
Name:	John Hobnobs2.JPG
    Happy now???
  5. #15
    No.............
    John S -
  6. #16
    ok guys you're making this look so easy, i'll check in later and see what he can when he's finished work.
    the text he was doing is a plate 235 x 178, 3 letter 63mm high on top row and four numbers on bottom row (8's appeared to be the problem)
  7. #17
    aaahh, You mean this ??
    John S -
  8. #18
    It is quite easy to do this in VectricCut2D. Here is one way . . .
    v01 create size of workpiece
    v02 enter text
    v03 draw rectangle around the outside
    v04 select the text AND the rectangle, then select 'create pocket'
    v05 in the pocket menu select the cut depth and the tool to use
    v06 in the preview window select preview toolpath and the computer will simulate the cut
    v07 Finished. Simulation runs at very high speed, and took about 10seconds
    v08 save the gcode created from this toolpath, ready for Mach3
    numberplate.txt is the Gcode
    numberplate.crv is the vectric crv file containing the toolpaths (which you might be able to view in your trial version)
    £117 well spent if you want to do this often . . .
    p.s. if you have the trial version of Mach3 you are limited to 500 lines, not enough to cut all these pocket areas.
ID:	2991   Click image for larger version.
ID:	2995   Click image for larger version.
ID:	2994   Click image for larger version.
ID:	2993   Click image for larger version.
ID:	2990   Click image for larger version.
ID:	2992   Click image for larger version.
ID:	2997   Click image for larger version.
    Attached Files Attached Files
  9. The Following User Says Thank You to routercnc For This Useful Post:
  10. #19
    im working with mates laptop to try and get resolved with artcam. this is a one off, yeah yeah, so i'm hoping to get it done with no expenditure.
    routercnc, you are a star, the level you have gone to in order to help is admirable and really appreciated. i hope you appreciate my "current" decision.
    atb
    compfranon
  11. #20
    You're welcome, hope it all works out.
  1. Replies: 15
  2. Replies: 5
    Last Post: 27-01-2014, 09:48 PM
  3. Raised Text
    By petesos in forum CAD & CAM Software
    Last Post: 02-04-2013, 11:21 AM
  4. how to fill/paint letters that i have engraved in wood ?
    By cockneyrebel in forum Wood Finishing Tips & Tricks
    Last Post: 26-03-2013, 11:21 PM
  5. Cutting wooden letters and shapes - purchase help for a newbie please!
    By kemo_2002 in forum Marketplace Discussion
    Last Post: 29-08-2012, 11:40 PM
