    "Could you just fix the leak under the sink?"
    It's the "just" bit that is so annoying. The problem is a platic pipe fitting with 2 tiny holes in it. It's on the boiling water tap so it probably didn't like the temperature.
    I can remake it in brass but WTF is the thread
    It's the same diameter as a 1/4" BSP but near as I can measure 22tpi.
    If it isn't BSP of NPT or Threadform or 14mm ISO, WTF is it?
    Anyone got a clue 'cause I haven't :whistling:
    Tricky to tell from here without seeing / measuring, but I would have thought it was a BSP thread?
    "It's the same diameter as a 1/4 BSP" - just one piece of advice (apologies if I'm teaching granny to suck eggs!) but 1/4"BSP, when measured, will measure closer to 1/2" - pipe fittings are different from standard screw threads in that regard, and it does confuse people.
    It isn't those quick-fit fittings for flexible pipe by chance (used in some radiator circuits, and similar in apperance to plastic airlines)? Pictures would be useful if you can get some.
    i2i's Avatar
    Quote Originally Posted by AdieR View Post
    I'm sure he's aware of that.
    :whistling:
    The 14mm iso bit gives it away
    Panic over, persuaded the olive to come off so all is revealed. Nut bent, new part coming, found it had a 5 year warranty, got it for free
    It's the plastic outlet fitting on the Franke 'Little Butler' tea making tap. I stuffed a silicone rubber tube on one end, finger over the other, immersed it and blew. Two tiny streams of bubbles, presumably on the opposite side to the plastic injection gate, looks like the weld line couldn't take the heat :naughty:
  1. WANTED: 150mm dia x 15mm wall Ali pipe
    By r0bsk1 in forum Items Wanted
    Last Post: 12-06-2014, 03:19 PM
  2. 3mtr CNC pipe profiling machine.
    Last Post: 23-08-2013, 07:49 PM
  3. Flexible Stainless Steel pipe that holds its shape?
    By Fivetide in forum Marketplace Discussion
    Last Post: 14-02-2013, 06:35 PM
  4. RFQ: Looking for someone to design and build me a cnc pipe router/cutter
    By D-man in forum Projects, Jobs & Requests
    Last Post: 07-11-2010, 12:59 PM
  5. your ideas on a pipe profiling machine
    Last Post: 03-11-2010, 04:09 PM
