Thread: speed controler
Page 2 of 2 FirstFirst 12
    on the speed controler breakout board i have a terminal block motor + motor -
    not the motor ....
    motor not connected
    just used meter on the -/+ terminals for the motor
    well removed the breakout board and hooked the speed controler up to my meter
    i think the controlers dead as it is showing 115v out put no mater what you you do with the potentiometer going to see what i does without later
    Lives in East Lothian, United Kingdom. Last Activity: 3 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,908. Received thanks 360 times, giving thanks to others 8 times.
    I'd be more inclined to test it with some sort of load on it, as the circuit may need to be loaded for the regulator to work.
    going to look in to getting some thing better
  1. Safe Z Speed
    By dudz in forum Artsoft Mach (3 & 4)
    Last Post: 24-05-2014, 04:08 PM
  2. HSM Advisor - High Speed Machining feed & speed calculator
    By magicniner in forum CAD & CAM Software
    Last Post: 20-01-2014, 12:57 PM
  3. Speed control
    By Saracen in forum Spindles & Drive Motors
    Last Post: 29-12-2012, 02:18 PM
  4. Adjusting speed with vfd
    By motoxy in forum Spindles & Drive Motors
    Last Post: 24-09-2012, 04:07 PM
  5. Top speed failing after a bit
    By Robin Hewitt in forum Machine Discussion
    Last Post: 12-11-2011, 12:46 PM
