    Anyone got any ideas for a homemade tool changer ....or a link ....... something simple but effective!
    cheers
    don
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Has been a member for 9-10 years. Has a total post count of 2,551. Received thanks 166 times, giving thanks to others 654 times. Made a monetary donation to the upkeep of the community. Referred 10 members to the community.
    Would that be for a lathe or?
  3. There was an extensive thread on CNCZone on this for a CNC milling machine... using a compressed air ram to eject the tool into the holder and some form of locking mechanism to pick the tool up. Not sure its a simple home build exercise tho....
    yea i saw that one ..problem is - its getting a bit complicated (there's a fella on youtube thats built one -- its real slow)- looking more towards something like those quick change posi -bit holder options ! I did find a thread on cnc-zone (don't ask me to find it again!! I can't --I've tried) but it wasn't suitable for anything over 10 000 rpm..... Lee its for a mill ...I got an idea of using the same type of tool changer as what you find on a lathe toolpost ( you know the wedge / dovetail variety).
    I do have an idea for one one but its going to be a bugger of a build .... imagine for a sec a normal tool holder ...looking at it from the top view --theres a wedge shape mounted ontop --about 10 - 12 mm wide tappering down to about 5mm ..... from the front (pointy end facing you ) the two longest sides will be dovetailed ....and the pointy end sloped downward with a small circular pocket milled into the top about 5mm deep.
    the spindle would have the other side (female) with a springloaded ''drawbar'' of sorts -- more of a ''pushbar''...so as the pointy end of the toolholder slides into the wide open end of the spindle ..at a point the ''pushbar'' drops into the pocket milled out ontop of the toolholder and locks the entire thing into position! .....to release --the ''pushbar'' is lifted by pulling the outer sleeve up ... i do have the alignment figured out --but thats for next --times short and i got to move ...
    too da looo
    simple tool changer could be a toolholder rack mounted at the extreme of your xy travel and a program to make the machine place the tool in the rack and get another out?
    If you want pics of a tool holder in bits, so you can see how it worked, I took the toolchanger off my mill as I wanted to keep it simple to start with.
  1. Replies: 16
    Last Post: 27-03-2014, 09:26 PM
  2. WANTED: EMCO Lathe Tool Changer
    By Pete92 in forum Items Wanted
    Last Post: 01-10-2013, 09:27 AM
  3. What Spindle / Auto Tool Changer?
    By Chaz in forum Tool & Tooling Technology
    Last Post: 01-08-2013, 09:35 PM
  4. how to make auto tool changer on mach3
    By m.vekariya in forum Artsoft Mach
    Last Post: 13-03-2013, 07:48 PM
  5. WANTED: Denford Triac with automatic tool changer
    By hugh_munculus in forum Items Wanted
    Last Post: 12-09-2012, 11:10 AM
