    Hi everyone!
    Ok, asked this before but it seems to have got lost and I'm at the point I need to start testing movement.
    Should I or should I not lubricated my ball nuts?
    Zapp's site implies not needed but others imply most definately needed. My ball nuts both came with grease nipples which would imply it is needed. I am told Shell Alvania II is a recommended grease to use.
    Also my Rack and pinion, ordinary lithium be ok on this?
    Hi Jeff, i cant see using some lubrication is going to be a bad thing. Grease will obviously give you more friction over oil, more things will help the grease to clog-up a bit to but then oil will burn up quicker.
    If you can keep it all fairly clean then i guess i would go with grease, i dont really have much experience with using diffrent grease's so i cant advise on that. I do use Lithium 2 for allot of my stuff.
    CM
    The ball nuts are already slight;u lubricated, but does have a position for a grease niple.
    I would suggest greasing the ball nut.
    Thanks chaps, we are over on the mainland tomorrow and I'll find a bearing mert type place and see what they have, I've been told that ordinary grease is too thick and to get something a bit runnier (think its called Shell Alvania)
    Many thanks for the help.
  1. Milling machine -maintenance? (oil, lubrication, specific questions)
    By diy-john in forum Milling Machines, Builds & Conversions
    Last Post: 24-02-2013, 09:03 PM
  2. Ballnut Lubrication / Grease
    By Mad Professor in forum Lead Screws, Nuts & Supports
    Last Post: 18-07-2012, 08:08 PM
