  1. #41
    Final alignment checks to see if I have met the Connelly prescribed 0.001" in 18" accuracy:
    one side was trammed to y axis then other face of block measured to z axis.
    block clamped to z ways and y axis traveresed
    similiar done to x axis.
    results:
    x-y 0.001" in 18
    y-z 0.0015 in 18
    x-z 0.0015 in 18
    I am going to leave it at that as I am loosing the will to live!
  2. #42
    final mechanical assembly:
ID:	4622 Click image for larger version.
ID:	4623 Click image for larger version.
ID:	4625 Click image for larger version.
ID:	4626 Click image for larger version.
ID:	4627 Click image for larger version.
    Just final wiring with shielded multi core back to controller and I am done, oh and I have to learn how to use the thing!
  3. Nice job Andrew ;-)
  4. #44
    It's alive!
    Did my first tests and it seemed to go ok. Machined some pockets in some scrap mild steel.
ID:	4787Click image for larger version.
    the pocket was 30mm x 20 mm and all dimensions seemed to be within 0.01mm of nominal (although this was just a quick check with digi calipers). I will do some more serious machining and see how a bigger part measures.
    Cost is a bit over budget as the electrical bits set me back more than expected but I recon the original machine, stock, hardware, motors, controller and computer cost me about £600. That does not include the extra tools I bought to do the job of course, they are an investment!
    I have enjoyed the project and have learned a lot from it. I hope you have enjoyed it too.
    hi andrew, the mill is looking great
    im planning to convert my centec 2 soon and i was just wondering...
    how do you find the screws? have they lived up to your expectations?
    what motors are you using?
    is there anything that you wish you had done differently?
  1. RFQ: Require small Stainless steel buckles machining- can you help please ?
    By Gasgasbones in forum Projects, Jobs & Requests
    Last Post: 15-05-2013, 06:47 AM
  2. Replies: 25
    Last Post: 03-05-2013, 09:31 AM
  3. RFQ: small cutout panel 66mm x 44mm - stainless steel 1mm thick
    By dsc in forum Projects, Jobs & Requests
    Last Post: 18-06-2012, 09:47 AM
  4. RFQ: small machining job??
    By Wobblybootie in forum Projects, Jobs & Requests
    Last Post: 25-02-2011, 01:04 PM
  5. Request for two small steel rod-esque lathed part!
    Last Post: 29-06-2009, 02:32 PM
