Thread: Motor noise
    What would I need to quieten electrical noise from a coolant pump being switched off.
    Single phase via a relay.
    Phil
    Sent from my HTC Desire using Tapatalk
    Lives in East Lothian, United Kingdom. Last Activity: 3 Hours Ago Has been a member for 9-10 years. Has a total post count of 2,147. Received thanks 236 times, giving thanks to others 5 times.
    On the AC or DC side?
    Have you got a diode to absorb the surge on the DC side from the relay being turned of?
    Thanks, the motor noise manifests itself as glitches in Mach3
    The way my relay is switched is as follows i use a solid state relay package that is operated by Mach3 via a bob
    This operates the bigger 240v 10a relay. I am switching the live and the neutral.
    My pump motor is single phase as was the spindle motor when i got the machine, it was run from a 13a plug.
    As i said in my post it only seems to happen at switch off.
    The coolant motor is maybe 20+ years old the spindle motor in new along with the VFD and they are quality makes.
    Phil
    Just to clarify, is the relay coil powered by AC or DC?
    For this bit, I'm going to assume AC, as DC switching SSR's aren't that common.
    Can you not power the coolant pump direct from the SSR?
    A coolant pump isn't likely to draw any more than an amp or so while running (any coolant pumps I've seen are only 1/3hp), although there will be a bit higher of a surge during startup.
    Also, I would try only switching the Live, so that the motor winding is still connected to something as it slows down.
    Hi and thanks, the relay coil is powered 12VDC
    Good point about the live only switching
    Phil
  1. Noise, Interference, and unexplained electrical behaviour
    By g4ghp in forum General Electronics
    Last Post: 24-04-2014, 10:39 AM
  2. Workshop & Noise Help
    By kemo_2002 in forum Workshop & Equipment
    Last Post: 12-04-2014, 09:16 PM
  3. 800w spindle - noise & controlling remotely
    By HankMcSpank in forum Generic Chinese Spindles
    Last Post: 17-10-2013, 05:26 PM
  4. Dell monitor making a funny noise !
    By Lee Roberts in forum Monitors
    Last Post: 13-09-2013, 11:11 AM
  5. The reason of noise of Engraving machine and solutions
    By Tomas in forum Machine Discussion
    Last Post: 26-08-2011, 09:41 AM
