    Kai's Avatar
    Lives in Hull, United Kingdom. Last Activity: 28-04-2016 Has been a member for 6-7 years. Has a total post count of 72.
    At the moment I am using bars of soap to test cuts but they are all quiet small.
    Is there any thing that anyone knows that is like saop etc the can be used to test cut the can be made up to be poured into modls etc please.
    Candle wax ?
    Phil
    Sent from my HTC Desire using Tapatalk
    Paraffin wax ... available from woodworking suppliers ... Liberon make it in 1kg lumps ... low melting point but reasonable price and easy to work with.
    Tim G-C
    I disapprove of what you say, but I will defend to the death your right to say it.
    (attrib. Voltaire but written by Evelyn Beatrice Hall "The Friends of Voltaire" 1906)
    Quote Originally Posted by Wobblybootie View Post
    Paraffin wax ...
    Candles are made from paraffin wax.
    Maybe a whole bundle would be cheap from a shop
    Phil
    Phil
    The big problem unless you use soap the cuts won't be as clean :rofl:
    Kai's Avatar
    Oh very good lol. Will candle wax be ok with a low melting point was not sure it would cut clean so to speak ?
    Kai another option if you want something more substantial to cut is plastic pallets if you can find them. Why not jut use MDF or wood? i always cut test pieces from wood before destroying a good piece of material.Even hardboard works as a cheap option if the cuts aren't too deep?
  1. CNC Router V1.0 (For Cutting Multiple Materials)
    By biketrialsdave in forum Gantry/Router Machines & Building
    Last Post: 05-08-2017, 02:37 PM
  2. DTI holders / bases for nonmagnetic materials
    By dsc in forum Tool & Tooling Technology
    Last Post: 11-01-2014, 11:56 AM
  3. BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
    By ciscoeuk in forum DIY Router Build Logs
    Last Post: 03-02-2013, 01:01 AM
  4. Materials used in CNC build projects
    By GeorgeD in forum Gantry/Router Machines & Building
    Last Post: 25-09-2010, 07:54 PM
  5. Mach3 - Test Cutting
    By sfallan in forum Artsoft Mach
    Last Post: 14-09-2010, 09:10 PM
