25-12-2010 #1
Hello to the forum,
I am finally getting on with renovating an old Kerry 1124 I picked up a few years back. Unfortunately some of the markings for the screw cutting gear box are damaged and no longer readable. Does anyone have a photo of the plate with the dial settings and gear tooth numbers? I would also appreciate any pictures of the end support for the lead screw and drive shaft. Any help gratefully received.
i am sure more info will be needed as work progresses.
Many thanks
Richard
27-12-2010 #2
Hi Richard
A good starting place would to have a look here http://www.lathes.co.uk/Kerry/page2.html
Kn8
27-12-2010 #3
Thanks KN8,
I had seen Lathes.co.uk when I first got the lathe and infact bought the manual. Unfortunately the cd doesnt work anymore and I need a bit more detail in the way of the odd photo. I have two immediate concerns
1 - I need to see how the drive shaft for the lead screw is held on the right hand side of thew lathe as i think i may be missing a few bits.
2 - The screw cutting plate is unreadable in places and although I was able to make out most of the figures I would like to be sure I got them right.
once again many thanks
Richard
27-12-2010 #4
Richard
Ping CNCEZEE a PM as i'm sure he could help you out with this project. He has i believe the same latheIf the nagging gets really bad......Get a bigger shed:naughty:
Help Uploading Photos
By ramsbury in forum General ComputingReplies: 2Last Post: 19-01-2014, 10:46 AM -
Hello - Kerry lathe from ebay
By Bossco101 in forum Milling Machines, Builds & ConversionsReplies: 17Last Post: 05-12-2010, 10:48 AM -
Waroc Minor photos for Irving2008
By rogertyrrell in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 02-09-2010, 12:44 PM -
Info on V23
By m.marino in forum CAD & CAM SoftwareReplies: 1Last Post: 14-10-2009, 09:18 PM -
Restoring old lathes, backlash in leadscrews
By irving2008 in forum Lathes, Lathe Rebuilding & ConversionsReplies: 28Last Post: 08-09-2009, 12:05 AM
