    Guys
    I'm just doing a single to 3 phase conversion on a lathe and just ordered a 3HP (2.2kw) phase inverter for it. I'm have to redo all the electrics completely and want to add a contactor and mcb fuses (replace the old ceramic bulb type). When i did my mill conversion i changed the motor to a single phase motor and reused the existing contactor without much thought. The question is should i rate the contactor at the fuseable value of the inverter (25amp) or go much higher?
    Quote Originally Posted by 2e0poz View Post
    That seems to be too high, i have a rotary inverter 5HP that is rated at 25amps
    Phil
    Have a look at the manual here.
    https://www.inverterdrive.com/group/...W/default.aspx
    This is the unit i have ordered
    it actually says 22amp on page 108
  5. When you say contactor, do you mean independently of the MCB, which should be 25A. If so the contactor needs to be rated for 25A switching, not carrying..
    Yes Irving i do
  1. gerber system 48 plus sizing problem
    By nodgeruk in forum Machine Discussion
    Last Post: 17-09-2014, 04:53 PM
  2. Relay V Contactor
    By GTJim in forum General Electronics
    Last Post: 18-03-2014, 09:10 AM
  3. help sizing toroidal PSU to stepper/drives
    By paulus.v in forum General Electronics
    Last Post: 28-01-2014, 05:40 PM
  4. Servo motor sizing?
    By gavztheouch in forum Stepper & Servo Motors
    Last Post: 18-04-2013, 10:40 PM
  5. Z-axis design - help sizing materials please!
    By Jonathan in forum Linear & Rotary Motion
    Last Post: 22-08-2010, 08:10 PM
