    Does anyone know where to get small quantities of gear box oil for mills? i.e. Mobilgear 627 / Shell Omala 100 in 5l quantities - I can only find 20l or 209l drums!
    i2i's Avatar
    Lives in Cardiff, United Kingdom. Last Activity: 30-08-2018 Has been a member for 9-10 years. Has a total post count of 693. Received thanks 30 times, giving thanks to others 0 times.
    would an auto gearbox oil suit..??
    edit... automotive gearbox oil not auto-gearbox oil.
    Possibly, however automotive and industrial gearbox oils are in different product groups in Shell's literature. I'm not an expert on oils - can anyone advise?
    i2i's Avatar
    i've got no idea either, just thought about the small quantities. An alteration to my first post, i meant automotive gearbox oil rather than auto-gearbox oil
    I figured you meant gearbox oil rather than trans oil. Automotive gearbox oil was my first thought, can't really see why not, I check with the machine supplier tomorrow.
    Lives in East Lothian, United Kingdom. Last Activity: 4 Hours Ago Has been a member for 9-10 years. Has a total post count of 2,148. Received thanks 236 times, giving thanks to others 5 times.
    Initially I was going to say any 100wt hydraulic oil would do, but having found a spec sheet, it looks like Omala has EP additives to make it more gearbox friendly. The most common EP additive used to be sulphur, however the spec states that Omala is bronze friendly, so it doesn't contain sulphur (sulphur attacks/disolves bronze).
    Personally, if it was my own machine, and I wasn't running it at high loads all the time, I'd stick some ISO100 hydraulic oil in, as lots of machines have specified and used normal hydraulic oil for many years (usually under the guise of Shell Tellus!)
    Other option is to use some of the more modern car gearbox oils, as they're pretty thin due to the manufacturers doing everything possible to improve effiency.
    Not sure if you sorted this out but I just got gear box oil from Morris lubricants.
    http://www.morrislubricants.co.uk/scripts/default.asp
    Really great help aiding in selecting the right oil for the machine.
    Ant
    Yes thanks, I got the oil from Oilswell, see link above. Good guy to deal with.
  1. RFQ: RFQ: Aluminium gear selector assembly
    By Bokoshoko in forum Projects, Jobs & Requests
    Last Post: 30-08-2011, 09:32 AM
  2. My first gear, a deadbeat escapement gear for my clock
    By clockman in forum Woodworking Project Showcase
    Last Post: 30-01-2011, 10:39 PM
  3. Gear cutting
    By John S in forum CAD & CAM Software
    Last Post: 03-10-2010, 06:55 PM
  4. Thats a nifty piece of gear isn't it
    By GeorgeD in forum General Discussion
    Last Post: 26-07-2010, 10:02 PM
  5. Where to get gear blanks in UK...
    Last Post: 03-01-2010, 02:19 PM
