Thread: Digitizing
  1. Good day all.
    I am wanting to start learning how to do Digitizing?
    I have a few things that I want to try digitizing.
    To start with I was thinking piston crown, and flywheel.
    But I don't know where to start.
    I don't have a multiaxis probe, so I will be doing it the cheap way, grounding the item, and using a 1mm tool connected to the probe port.
    So I would like you help and advice, on how to get started.
    Thanks for your time.
    Best Regards.
    "If first you don't succeed, redefine success"
    Lives in East Lothian, United Kingdom. Last Activity: 7 Hours Ago Has been a member for 9-10 years. Has a total post count of 2,033. Received thanks 223 times, giving thanks to others 5 times.
    Only thing relating to digitizing I've ever stumbled across, is the video digitizing board on the mach forums - http://www.machsupport.com/forum/index.php?board=67.0
    I havent tried any scanning myself but i have heard that the probe method can run into hours scanning relatively small parts then you need point cloud compatible software to make sense of the file.
    Maybe have a look here http://www.david-laserscanner.com/
    Phil
  1. Mach3 digitizing wizard not saving file
    By dudz in forum Probing, Digitizing & Scaning
    Last Post: 08-09-2013, 08:48 PM
  2. Digitizing probe / Point cloud to mesh
    Last Post: 07-09-2013, 09:03 PM
  3. Digitizing probes practicality
    Last Post: 04-06-2013, 02:31 PM
  4. Probing / Digitizing - What the best way to do this job?
    By Mad Professor in forum Probing, Digitizing & Scaning
    Last Post: 08-05-2011, 11:32 AM
