Thread: Problem with X
    When I brought my CNC I also brought a new motherboard, which did not have a LPT port on it so I fitted a PCI-E LPT card, I soon found out I had no X axis, so I used and old PC with a built on LPT, no problems I assumed the problem with the new board was low voltage so I brought a LPT Buffer and re installed the first PC problem guess what same problem, any one come across this before? is it a pin out problem?
    Are you sure the port address is correctly assigned! Sometimes, the bios will pick up a strange address.
    Art
    AKA Country Bubba
    (Older than Dirt)
    Yes, its the address that's on resources for lpt
    Do the other axis work? If so, sounds like a possible connection problem because you say it works on the old computer. Are you using the same cable from the computer to the breakout board for both computers?
    Art
    AKA Country Bubba
    (Older than Dirt)
    yes Y & Z work fine if i swap leads on the controller X works, same leads, could it be it needs a different pinout for X?
    If everything works on the old computer then possibly you have a bad lpt? I am drawing at straws here, but try switching the pinout if you can and see what happens!
    Good luck
    Art
    AKA Country Bubba
    (Older than Dirt)
    What other pinouts would control X? is there a device/software that will detect LPT output
    Did you setup the pinout in your controller program on the new computer? All of the control programs (Mack, Turbocnc, CncPro, etc) require you to configure the system and tell it which pins to use for the various functions.
    Usually "most" people use parallel port pins 2 and 3 for step direction of the X axis. You previously stated this was a 3 axis machine, so possibly you could use pins 8 and 9 but you will also have to rewire your breakout board etc.
    Art
    AKA Country Bubba
    (Older than Dirt)
    It seems strange, with the other PC no problems i am using the same software set-up same cables only difference is the buffer and the LPT output, what I was wondering is would the LPT card be using a different pinout, but I cant see why, I am going to borrow a USB to LPT and try that through the buffer see it it helps, fingers crossed, Im new to CNC so its all a learning curve
    USB to LPT to my knowledge has NOT worked for anybody to date.
    Did you try it with the "buffer" and the old computer?
    At this point, I am at a loss without sitting down with you and a meter to try and diagnose the system. That would be rather hard as it is a long swim to your place:})
    Art
    AKA Country Bubba
    (Older than Dirt)
  11. The Following User Says Thank You to C_Bubba For This Useful Post:
  1. Powertran VFD problem
    By phill05 in forum Spindles & Drive Motors
    Last Post: 29-10-2013, 06:59 PM
  2. Bearing fit problem
    By paulus.v in forum Linear & Rotary Motion
    Last Post: 09-10-2013, 08:54 AM
  3. z axis problem
    By rickybabe in forum Linear & Rotary Motion
    Last Post: 28-04-2010, 08:04 AM
  4. Problem with calibration
    By m.marino in forum Gantry/Router Machines & Building
    Last Post: 22-04-2010, 03:19 PM
  5. Z Problem
    By airwolf in forum Machine Discussion
    Last Post: 10-11-2009, 07:08 AM
