    Some of my parts have arrived so its time to get the build started. The bed frame is 1250mm long by 1065 mm wide. It will be running on linear rails and bearings with ball screws driven by NEMA 34 motors.
    The whole assembly will sit on a purpose built angle iron frame with adjustable feet to level it.
    Pics 25, 28, 29, 30 show the extrusion and the built base frame with part of the linear rail attached. 26,27 show the bearing riser plates and the y-axis risers. 14 shows the bearing mount plates and the risers and 16 shows how they fit together.
    I havent got the ballscrews yet and some of the motor mounts are out of stock but should be here soon.
    Hopefully tomorrow I will finish fitting rails for the x-axis and get the bearings and mount plates fitted. Then I have to work out the mounting plate for the frame to fit to the base which will also mount the motors and the ballscrews. If I can get that done tomorrow I can get them cut out on the Laser at work Monday.
    I need to figure out attaching photos as well
    Regards
    Ian
ID:	3615   Click image for larger version.
ID:	3623   Click image for larger version.
ID:	3622   Click image for larger version.
ID:	3621   Click image for larger version.
ID:	3620   Click image for larger version.
ID:	3619   Click image for larger version.
ID:	3618   Click image for larger version.
ID:	3617   Click image for larger version.
  1. BUILD LOG: It's begun....
    By Washout in forum DIY Router Build Logs
    Last Post: 07-06-2015, 10:03 AM
