Thread: need help
    k2me's Avatar
    Lives in wexford, United Kingdom. Last Activity: 24-01-2011 Has been a member for 9-10 years. Has a total post count of 9.
    Hi every oone just wondering if any of you can help i have morbidelli 504 and ive just set it up but the electro spindles are going in the wrong direction. any one ever have the same prob or how will i fix this thanks.
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,908. Received thanks 360 times, giving thanks to others 8 times.
    Just done a quick google, and see that's quite a 'substantial' machine!
    I'm guessing the spindles will be powered by 3 phase, so it sounds like you just need to swap two of the 3 phase wires around, which will change the direction of all the 3 phase motors.
    k2me's Avatar
    hi thanks ive thought of that but because its a electro spindle changing the wires wont make any differance as far as i know i think its got to do with the signal the machine is sending to the motor im not sure if there is just a setting on the set up that you can change when loading the program.
    How are you starting the spindle
    G code, MDI, hardware panel button ?
    Phil
    Sent from my HTC Desire using Tapatalk
    I would of thought the spindle on that size of machine would be some form of 3 phase motor, either powered directly or via a VFD.
    Swapping the wires to the machine would only take a couple minutes, and rule out it being something that obvious...
    Is it possible to control the spindle speed?
    k2me's Avatar
    hi phil startin it with g code runnin a program
    k2me's Avatar
    hi swapped the supply today made no change to the direction. would have been i nice fix if it worked
    Quote Originally Posted by k2me View Post
    OK it may be the post processor.
    On MDI try M3 normal spindle forward
    Try M4 spindle reverse
    M5 is spindle off
    Just put whatever works in the PP
    Phil
    k2me's Avatar
    ok cool ill give that a go and ill see what happins
    thanks phil
    zebbyz's Avatar
    Location unknown. zebbyz Last Activity: Has a total post count of n/a. Referred 6137 members to the community.
    Did you get any manuals with your 504 ? I have the full parts manual for it 729 pages - 5 languages ... but after an operators manual or something useful ... !
    And what have you made on your 504 ?
    g
